  #21
Old 01-04-2013, 03:38 PM
XStar08's Avatar
XStar08 XStar08 is offline
Boat: MasterCraft XStar, 08, LY6; MasterCraft ProStar 190, 91, Ford Mustang;
Don't forget to change oil before the boat is set for winter otherwise stuff will set down and fresh oil in spring will get dity by that stuff on the first time you fire up...
Old 01-04-2013, 03:50 PM
Flatwaterfooter Flatwaterfooter is offline
Boat: 2006 PS 197
Did not do that and will not be able to without firing the engine up again. Moving forward I will do the oil in the fall.
Old 01-04-2013, 03:53 PM
XStar08's Avatar
Jep, thought it's a little late for my hint. However thought to share that info, as you where saying for next time usage...
Old 01-06-2013, 02:36 PM
GoneBoatN's Avatar
Boat: 2010 X-15 w/MCX
Originally Posted by east tx skier View Post
... Disabling the fuel pump is the way to do it if you don't turn the engine over manually by hand...
I use a remote starter switch attached to the starter. The starter is "hot" with the battery switch on but the ignition is off. Since the ignition is off I think the fuel system and the ignition system would be off. Not being 100% sure I disable those anyways via removing the relay to the fuel pump and the wires to the HVS.
Trying to turn over the engine by hand on a v-drive = No Joy
