#41
Started working on the trailer today. One step closer to get her put back in the cradle. Hopefully will start fiberglass work this weekend.
#42
I need to see the whole trailer, but are your bunks all the way outside on the chassis rails? Is that a Mastercraft trailer? My bunks are some way inside the chassis.
#43
Bstewart0529 You in the Charleston area?? Im pretty sure I saw that boat out at Bushy Park early last year.
#44
yep you probably did.
#45
SO could you please give me some measurments, would really appreciate it. Can you place a board across the back of the trailer (placed on the 3" channel) and let me know the distance between the top of the metal cross piece of the prop/rudder guard and the bottom side of the board. Also if you could take a plumb bob and line it up with each bend and give me a distance from the edge where each bend is made, last measurment would be for the length of each bend. Thanks ahead of time for your help. |
#46
finally
We will get started this weekend. The holiday's had me a little back up. But looking forward to getting her patched up and ready to go.
#47
Great - can't wait to see the repair.... I wonder why 3M uses sells a polyester resin for repair vs. vinyl-ester. I know expoxy is strongest then vinyl...then polyester. MIskier indicated that MC uses Vinyl-ester when building. Please post lot's pic's building my library of methods for my project boat to come.
.. found this video at jamestown distributors... http://www.jamestowndistributors.com..._1441&type=plabeing a nube to repair - does the patch need a backer of some sort to reinforces the repair? I mean - once you fill the whole do make a resin/glass patch larger than the hole to keep make it all strong? My thoughts are what happens to the joint where the new glass/resin meets the old laminated class and resin. This is so much more interesting than what I do for a living... ![]()
I have already put a piece of wax paper on the bottom of the boat. The first step will be to put a peice of the smaller weave fiber and a little resin. Once that is set then I can remove the wax paper and then yes the peices after the hole has been filled then will be larger than the hole. I do have epoxy resin to use on coats that will go on after I get the hole filled in. I will take more pictures don't worry.
#49
No more hole!
I can now say I no longer have a beautiful boat with a hole in it. These some pictures from today. We will continue next weekend
#50
Pictures from today
