confirm
I want to confirm i winterized properly. I have to move the boat from indoor heated sstorage to an unheated location. Engine is an MCX i drained block and all hose, blew out the shower and got water out of heater. Once done reattached all hoses and ran 5all gallons of RV antifreeze through till it cameto out exhaust. Should i have any concerns or should i be fine.
i have never done it myself but what about your ballast system? don't forget to pull both drain plugs out too so rain-water can drain out of the hull.
"Tropic corridor, tropic treasure. What got us this far to this mild equator? We need someone, something new....something else to get us through" (James Douglas Morrison/The Doors) |
No ballast PS 197 and the storage will still be indoors, but plug is out. Thanks
should be good......
Thanks one final question any issues with transporting the boat about 40 miles will i loss antifreeze
Sounds like you did it right. I'm not a boat mechanic but I did stay at a Holiday Inn last night....
![]() Sent from my wife's old iPad using Tapatalk....
If its not a competition ski boat, its always second best. ![]() 1994 MasterCraft ProStar 205 275 HP 350 Chevy Indmar Monster Tower & PerfectPass Check out the MasterCraft Buckeye Bash on Facebook! "In my many years I have come to a conclusion that one useless man is a shame, two is a law firm and three or more is a congress." - John Adams |
what'd you do with battery/batteries?
Removed battery. This is first season with the MCX always dry blocked my LT1 so justthe want toto be sure-
Sounds good so far.
Fog cylinders thru spark plug holes, crank it over a couple times with lanyard pulled I usually pour pink RV anti-freeze into the heater core after blowing all the water out. Spray engine with WD-40 What lake in NH? Lake Winnie?
I was njskier on here. |
did you remove knock sensors to drain water from the lowest point of the engine block?
