Old 12-29-2012, 08:31 AM
wats218's Avatar
wats218 wats218 is offline
Boat: Mastercraft, ProStar 190, 1996, Chevy 350
Send a message via AIM to wats218
Knock Sensor Removal Trouble
Winterized the boat about a month ago. Drained the exhaust manifolds and port side block plug, pulled the thermostat, and then ran 5 gallons of rv antifreeze out of a bucket through the entire engine. There was definitelt]y red antifreeze coming out of the exhaust.
I've been doing some reading on this site and it seems that everybody removes the drain plug on the starboard side of the block as well. Since I use the cheap rv antifreeze, I figured I'd do the same just in case the antifreeze was diluted too much. On my engine, this drain plug has the knock sensor on it. I got a 7/8" wrench and started turning the knock sensor to remove it. My problem is that the center hex head spins, but the outside housing and the threads in to the block do not. Is there a trick to removing the knock sensor? Did I damage it? The center hex does not spin smoothly, more in rough steps. Below is a link to skidim for the knock sensor that I have.
http://www.skidim.com/prodinfo.asp?number=R020027
Old 12-29-2012, 09:11 AM
ProStar Slalom's Avatar
ProStar Slalom ProStar Slalom is offline
Boat: 1984 S&S, 2001 19 Skier
I've got the same sensor and just loosen with a wrench as you describe; never had just part of it turn, so it sounds like something isn't right. I'm sure a better wrench will jump in here shortly.
Old 12-29-2012, 11:28 AM
MCOCD@13 out of 10
sounds like time for a new knock sensor. appears outer housing loose from over torquing when installing over there years. It only has to be snug.
Old 12-29-2012, 11:36 AM
MLA MLA is offline
Boat: pontoon
Loosen is up with a pair fo slip-joint plyers on the outer body. I would then suggest replacing it.
Old 12-29-2012, 11:46 AM
jakethebt's Avatar
jakethebt jakethebt is offline
Boat: '96 Prostar 205 LT-1
What he said^^^^^^
1996 Prostar 205 LT-1
Old 12-29-2012, 12:07 PM
EricB EricB is offline
Boat: 1983 Stars and Stripes Powerslot
I 3rd what MLA suggests.
Old 12-29-2012, 01:34 PM
wats218's Avatar
Thanks guys. I just wanted to make sure before I took pliers or vice grips to the outer housing.
Old 12-29-2012, 03:55 PM
Jerseydave's Avatar
TT Hero
ditto, the outer housing is peened over to the inner part. Small pipe wrench on the outside should take it out, then replace. I take mine out every year to winterize.
I was njskier on here.
Old 12-29-2012, 09:11 PM
MCOCD@13 out of 10
Hey I learned a new word today... and the wives laugh our boating addictions..
Old 01-02-2013, 04:12 PM
94PS190's Avatar
94PS190 94PS190 is offline
Boat: 94, prostar 190, 96 prostar 190..anyone wanna buy one
I don't know what slip joit plyers are, but I would use dogs, or channel dogs to be more specific,
