  #2201
Old 12-26-2012, 02:24 PM
Kyle's Avatar
Kyle Kyle is offline
Boat: 93 Prostar 190
Originally Posted by byronic View Post
Great way to do teak, but don't forget the safety rules. Linseed oil and turpentine on a rag crumpled up can spontaneously combust! Don't ruin a nice teak job with a fire.Lay the rags out to dry or soak in water.
Linseed and mineral spirits have never combusted spontaneously. Doesn't mean it can't. I just never thought of that. So thank you
Maybe I'll try linseed and turpentine vs wasps next year.
Rollin' Gangsta Style
Old 12-26-2012, 03:50 PM
GoneBoatN's Avatar
Boat: 2010 X-15 w/MCX
Originally Posted by Kyle View Post
You will know real quick if you did it right or not.
The light drag is really enough to have the shoes touch the outer (hopefully round) drum. Like barely touch it. Just enough to make a rubbing noise.
If you are too tight going and retrieving your empty trailer will be interesting as the wheels would lock up real fast when driving around without the weight of the boat on the trailer. Wheel hop and lockup would be extremely easy on a light trailer.
Everyone here described how it should be done correctly. I just wanted to give a result incase you happened to have them too tight because you are so strong
I can't even believe that 5 clicks back from locked up would even be correct. That would burn those shoes up real fast and you would get lock up and possibly not be able to back up or extreme wheel hop when empty.
Sounds like you are good though.
Cheers
I agree with everyone else as well. Just to add a little (did not see it mentioned), 1st time out with boat on trailer, stop after a short distance (about a mile or so) and feel the hubs to make sure they are not heating up too much. I was able to tell that I had one side a little tighter than the other because one side was a little warmer than the other. Repeat the check again about about 5-10 miles just to be sure.
Old 12-26-2012, 04:21 PM
SP Maristar's Avatar
Thanks for the tips Kyle and Gone. I still feel good about my adjustment. Unfortunately I won't know for a while.
Our first outing in the spring should be interesting. I have touched so many things this winter so far. Fuel filters - possible leak/fire if not reinstalled properly. The trailer brakes as we have discussed. Many water hoses - could leak like mad and overheat. Spark plugs/wires - could misfire. Engine detailing - did I bump a wire loose? Fogging - lots of smoke on startup...
Probably worrying for nothing, but like I said, the first outing in the spring will be interesting.
Old 12-26-2012, 06:00 PM
JDC's Avatar
JDC JDC is offline
Boat: 2004 Prostar 209 - MCX
... I can't even believe that 5 clicks back from locked up would even be correct. ...
Cheers
I'm with you Kyle, on the 5 clicks back seems like not enough. Maybe they're big clicks. Seems like a weird way of doing it also, but... whatever works.
I usually go about it the other way. Tighten one or two clicks at a time until I hear something, then back it off one, maybe two. Again, whatever gets the same adjustment result.
Originally Posted by SP Maristar View Post
... Probably worrying for nothing, but like I said, the first outing in the spring will be interesting.
SP Maristar, I have a feeling everything you touched will be fine.
Jeff
Old 12-26-2012, 06:21 PM
Thanks for the vote of confidence, JDC. My wrenching days are mostly over, but I 1) needed to become familiar with the boat and winterizing was the perfect opportunity, and 2) none of the wrenching so far has been that difficult. I hope it stays that way...
Old 12-27-2012, 08:22 PM
byronic's Avatar
byronic byronic is offline
Boat: 86 19' skier 351 PCM
They don't ignite in the can or on the brush, only the soaked rags if there in a pile.
Old 12-27-2012, 09:46 PM
Thanks ... was just lurkin' and then just busted out laughin'
Old 01-05-2013, 02:49 PM
TOO-TALL's Avatar
TOO-TALL TOO-TALL is offline
Boat: Mastercraft X2 2003 mcx
Sanded and oiled.....the 80/20 mix is awesome!
---Animal house
Old 01-05-2013, 03:55 PM
Looks nice...can't wait to get it wet... ...
Old 01-05-2013, 05:05 PM
Kyle's Avatar
Looks real nice TooTall
