  #81
Old 12-22-2012, 02:06 PM
Worthing skier's Avatar
Boat: mastercraft prostar 190 1993 & 1996
Originally Posted by Kyle View Post
Yes there is a difference in distributors and cams with the different rotations.
The cam gear will be one or the other on the distributor and the cam itself is cut to a specific rotation.
Ok ,I did not think of that ,
so if I buy a new distributor as listed on ebay ,
I should then be able to just swap the drive gear from the old to new unit ?
Thanks
Kevin
Old 12-22-2012, 02:08 PM
Hi there
Thanks for the tip ,
I did try them for the gasket set but were a bit on the heavy side of pricing,
I will see if I can use the 1 I found on ebay and swap the drive gears .
kind rgds
Kevin
Old 12-22-2012, 03:11 PM
Kyle's Avatar
Kyle Kyle is offline
Boat: 93 Prostar 190
Thanks
Kevin
Hold on now, there is more to this. The cam drive gear in the two pictures has the same rotation. The drive gear is not zip zip zip easy to swap out. The little pressed in pin is the easy part in removing or installing the cam gear. The drive gear is pressed on to the distributor shaft, the brand of distributor will more than likely have a diameter specific cam gear (they are not generic shaft size diameter LH and RH gears), and the legnth of the shafts can be different.
After comparing the 2 distributors they appear to be the same. Same gear rotation, same size gear, and same legnth.
That's a good price on the eBay buy it now.
Contact seller for shipping
Rollin' Gangsta Style
Old 12-22-2012, 04:43 PM
Thanks Kyle again ,
Just waiting on some shipping costs , but with the holidays now here it may slow things up a bit .
Old 12-22-2012, 05:52 PM
lazyade lazyade is offline
Boat: '92 190 Prostar and the new project '05 X Star (Indmar 350 MCX)
Hey Worthing, me and a mate are in the middle of restoring a 2005 XStar, we have the GM 5.7 engine, but very similar to yours. When we stripped our downs it looked not too dissimilar to yours inside. We purchased a new engine from Michigan Motorz in the US, cost $2,300 or so. We also purchased an electrical pack, with new distributor, coil and HT leads. Shipping and taxes was about £800 on top. Way cheaper than from the UK, plus we now have a brand new long block with zero hours.
'92 190 Prostar 260hp Indmar.
Old 01-05-2013, 06:28 AM
Well a bit of an update ,
heads now stripped down , all 8 inlet valves badly pitted so will need a set of inlet valves .
Block is also out , so next bit is to see whats been going on in side .
Kevin
Old 01-10-2013, 02:19 PM
Hi all
Next bit I am trying to sort is either a rebuild on the TBI or replace completely ,I have found this
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=281048468686
Is this okay for my application , or can anyone advise on where to get any rebuild parts for it .
thanks
Kevin
Old 01-12-2013, 05:23 AM
Hello
I am still trying to find information on the TBI and injectors , does anyone know the part number for the injectors and also a supplier for a TBI gasket set and fuel pressure regulator .
Many thanks
Kevin
Old 01-12-2013, 07:34 AM
Hi all
thanks
Kevin
Looks identical to mine..
Old 01-12-2013, 07:36 AM
Hello
Many thanks
Kevin
Try summitracing.com they may be able to help.
