Old 09-30-2012, 11:23 PM
MCOCD@13 out of 10
Originally Posted by mondos829 View Post
impeller it was. Attachment 84880
It's toast...thought you said you check in post #1?
Old 10-01-2012, 09:37 AM
mondos829 mondos829 is offline
Boat: Mastercraft, 1976, Stars and Stripes, Ford 350 GT
I did. i saw the veins but didnt see how extensive the damage was. Best advice. try and blow through the pump. if air passes through impeller is done. Just ordered 2.
Old 10-01-2012, 01:17 PM
onewheat's Avatar
onewheat onewheat is offline
Boat: 2007 Mastercraft X-15
impeller is 2 months.
?????????????????????? That is the worst 2 month old impeller I've ever seen.
onewheat
2007 X-15
Old 10-01-2012, 08:43 PM
MCOCD@13 out of 10
The only thing I can think of is there was an interruption of water and the impeller over heated. OP mentions strainer - notorious for air inline if not sealed properly..... no water - heat...bye bye impeller..so sad...
Old 10-01-2012, 11:44 PM
Masterfull Masterfull is offline
Boat: Mastercraft Stars and Stripes 1985 351
You will need to find all the pieces that came off of that impeller as well as any pieces that came off of any prior impellers.... Check all hoses and coolers down line from the pump....You may also find pieces of impeller in the intake hose prior to the pump... Backflush all the hoses and try to account for all missing vanes.... And by the way, where are you in the northeast....I'm in MA.
Old 12-19-2012, 08:09 AM
wheeler's Avatar
wheeler wheeler is offline
even new impellers can go bad. one common problem is the brass inner separating from the rubber, the impeller looks fine, but only the inner center is spinning....it baffled me for a couple hours on the lake one day.
if water pick up screen is clean, tranny cooler is clean, hoses on correctly......change the $40 impeller. :-)
2004 X-10 MCX350
