Old 12-18-2012, 02:30 PM
TxsRiverRat's Avatar
Boat: 93 Prostar 205
Originally Posted by SkiDog View Post
Custom made motorbox vents/drinkholders for early 90's prostars.
Eddie - send me your contact info - I'm ready and your PM box is full!
Old 12-18-2012, 03:17 PM
Jim@BAWS's Avatar
Jim@BAWS Jim@BAWS is offline
Boat: 1996 PS 190 LT-1/Powerslot
I can vouch for Eddie's work. I have seen the prototype and the finished product
They look great
Jim@BAWS
Tampa Bay's Exclusive MasterCraft Dealer
www.BAYAREAWATERSPORTS.com
(813) 996-BAWS (2297)
Old 12-18-2012, 03:26 PM
clrussell's Avatar
Boat: 1990 mastercraft p190
Thanks for the link, maybe I can do something like that to my prostar this winter
Tapatalk
Old 12-18-2012, 04:49 PM
SkiDog's Avatar
SkiDog SkiDog is offline
Boat: 92 Prostar
I replied to your email.
Old 12-18-2012, 05:00 PM
I haven't received anything
Old 12-18-2012, 05:13 PM
tph's Avatar
tph tph is offline
TPH, both of those custom additions look very solid and nicely done.
What did you make the plate out of? Do you do all of your own fab?
Thank you. I get a little OCD when it comes to the boat. Yes, I do my own fabricating. The plate and the attachment assembly are made out of fiberglass. I built a mold and layered many sheets of glass cloth followed by a matching grey gelcoat (which was available from MC at that time) The hardest part was drilling the holes in the transom to mount it. It wasn't physically difficult, I'm just not wild about drilling holes in the boat, especially below the waterline.
Old 12-18-2012, 05:14 PM
rodltg2 rodltg2 is offline
Boat: SN196
Send a message via AIM to rodltg2
Originally Posted by tph View Post
Thanks! I'm surprised the 197 has a rooster tail at those lengths, but have never been pulled by one. I doubt this would help as the plate was designed to close the back of the PowerSlot and I think that concept has already been incorporated into the ProStar hull since '86.
does it work? have any before and after pics of the wake?
Old 12-19-2012, 05:51 AM
eurosysytem0 eurosysytem0 is offline
Boat: X7 MCX350
Originally Posted by clrussell View Post
Do you have any more build info on this!!! I'd love to see more ! What's it look like with bag full? Does pad sit flush with sun pad?
Tapatalk
See my answer to Sammy02 below plus the link he provided which shows more
Old 12-19-2012, 06:22 AM
Boat: X7 MCX350
No drawings.Cirussel. The second photo shows sac fully filled but without seat cushion install. Remember its now filling vertically.
http://www.mastercraft.com/teamtalk/...651#post755651
The aim was to ensure that when the Fat Sac filled, it filled "vertically" within the seat footprint instead of filling flat (like a fat slug which looked C**P and blocked walk space between engine cover and seat) also deforming and pushing out the MC 4" seat kicker board.
When installed (less than a minute), the seat cushion still sits on the standard MC SS side grab handles in sundeck position and therefore is still level with the rear deck.
The existing seat rail under seat sits forward of the new panel thereby retaining/trapping the top edge of the new retaining/fascia board. The gaps under the MC SS side grab handles still allow the rubber bungees to be attached to seat fasteners locking the seat cushion (sac compartment top) and the new fascia board in place (compartment front). The MC seat kicker panel fits in one of the side compartments
When installed the Fatsac is completely hidden, the sundeck/seat can be used and there is still a clear walkway around rear of engine (exactly the same as when seat in seat position).
Another feature is the new fabricated sloping bottom panel that the sac sits on ensuring that the Fatsac completely empties. It slopes and drains towards the pump empty pipe on the starboard sides. The two cut outs in the bottom panel are to allow the pipe connections ( two inlet/one outlet to sit against the floor of the boat and not compressed into the sac.
As my daughters each specialize (one slalom, one wakeboard) I am regularly filling and emptying sac. This modification has improved emptying time and I get much less of the pump running air waiting for the water to drain. Needless to say I dont assemble and disassemble the new container when I fill and empty. However, if I need the rear seat, the new front fascia panel slides between drivers seat and side of boat. Also the empty sac still compresses enough for seat to go down fully into MC position without removing the sloping bottom panel.
So bottom line loads of upsides- no down sides. In terms of fabrication, I just made cardboard templates and then cut in marine ply. Used marine wood glue/brass screws and the covered in a matching marine carpet. Then made and X7 stencil and sprayed the logo/decal with gloss paint.
Hope this helps
Old 12-19-2012, 06:28 AM
Boat: X7 MCX350
Whoops. deleted a duplicate message
custom boat parts, do it yourself, homemade
