![]() This is very interesting. Bought my 91 in Jan 04. In the process of giving it the once over before my first season I stumbled across the zerk on the steering cable tube. Saw it was missing the check valve. Looked high and low for a replacement zerk. It's very small, 3mm or something like that. I even called a dealer. Told them which zerk it was and why I wanted to replace it. They never mentioned anything about it being by design. I eventually tapped it out and put another zerk in there with a check valve. Also changed steering cable and cleaned out that tube. Haven't had any trouble. When I grease it I wipe everything down several times as I move the rudder back and forth slowly to ease excess grease out. My steering is actually very nice but of course now I'll be aware of it and MCOCD will begin to eat the brain. Guess if it comes to it I can pop the bearing out of the valve. ![]()
http://www.metroplexskiclub.com |
#22
#23
did anybody ever figure out where to find that steering guide tube zerk? mine is missing too...any issue with not having it there? every hardware zerk protrudes too much into the cable...
any info on thread specs, depth etc. So far i only know it doesnt have the check valve....
I won't call myself a hero...I'll let history decide. |
#24
Rollin' Gangsta Style Quote:
#25
I found a grease zirk that fit the hole size and then ground it down so it did not protrude through the other side into the tube and then I greased the heck out of it. Mine is working great but it is spring and I have been out once. I posted my step to fixing on my X-9
http://www.mastercraft.com/teamtalk/...t=53412&page=2 |
