#31
However, power launching would take more time than what I'm currently doing (floating the boat off), because of the skills and comfort zones of those with me. And - - - knock on wood - - - I've not had an engine fail to start in more than a decade. I think the chance of a boat failing to start is pretty low. I will also crank the boat in the driveway prior to leaving, just to make sure the battery is alive and well. I'm not sure if people are for or against *that*, but I'd rather know if there is juice in the system before heading to the lake. |
#32
A few years ago I summarized the boat in the driveway prior to going to the lake. Everything worked fine, it fired right up, as it always did. When I arrived at the lake an hour later I confidently backed the boat in the water, knowing that I was prepared. I turned the key: nothing! The engine was still warm! Somehow, on the 20 minute drive to the lake, one of the wires on the ignition switch loosened up just enough so that it wouldn't crank. All of a sudden I was "that guy". No one else there was interested in my explanation of what happened, I was just another guy tying up the ramp whose boat didn't start. |
#33
After writing my post, I read a number of messages contending that it is bad to crank your boat out of the water . . . bad for the impeller, which then can fail and overhead the engine. I guess I can understand that in theory, but I question if 1 second of cranking will damage the impeller (which I will continue to replace yearly.) |
#34
