Old 12-15-2012, 02:29 PM
Kyle's Avatar
Kyle Kyle is offline
Boat: 93 Prostar 190
Fixing stiff steering
Here is a thread on how to fix your stiff steering.
Stiff steering could be a bad cable, stale grease in the rudder box, a bad helm, or stale grease in the cable housing.
After gaining access to the steering cable and rudder box, remove the cable from the box and remove the cable from the bracket that holds the cable to the hull.
It should now look like this.
Rollin' Gangsta Style
Old 12-15-2012, 02:30 PM
Kyle's Avatar
Then remove the cable from the bracket like this
Old 12-15-2012, 02:33 PM
Kyle's Avatar
Taking the cable apart like this will not require re-adjusting of the steering wheel.
Clean the inside of the steering bracket tube. It will be full of old nasty grease.
Old 12-15-2012, 02:34 PM
Kyle's Avatar
Then clean the cable that goes in the tube real good.
Old 12-15-2012, 02:38 PM
Kyle's Avatar
Following that step turn the wheel all of the way to where the cable fully extends.
Clean this part of the cable real nice.
At my finger the outer cable housing goes over the inner cable.
Run it in and out several times cleaning it good. I soaked the cable in WD40 and ran it all the way from right to left and cleaned it then repeated several times.
Old 12-15-2012, 02:43 PM
Kyle's Avatar
Cleaning the outer housing was hardest.
I took an oil drain pan and put some gas in it. I ran gas through the tube.
Then take a paper towel and cram it into the tube and find something to ram rod it all of the way through.
I was not willing to use my shotgun cleaning tools so I used a paper towel and a broken golf club.
Now everything is clean and dirt free.
Old 12-15-2012, 02:45 PM
Kyle's Avatar
Then I took the rudder out of the rudder box.
Fortunately it was clean and no work was required.
Also I'm lucky as my trailer oils not let the rudder come out all of the way. It was dropped down enough to know 100% that it was not dirty. It was real clean.
I re assembled that. No pics sorry
Old 12-15-2012, 02:46 PM
Cloaked Cloaked is offline
Boat: MasterCraft
Nice shoes.....
Old 12-15-2012, 02:47 PM
Kyle's Avatar
While doing this project I noticed a hole in the tubing.
This is where a grease fitting used to be. I am headed to find a new fitting now so more info coming after I get back from the store.
Old 12-15-2012, 03:04 PM
Kyle's Avatar
Nice shoes.....
Thank ya sir
