  #41
Old 11-03-2012, 09:12 AM
JDC's Avatar
JDC JDC is offline
Boat: 2004 Prostar 209 - 350 MCX
Originally Posted by mxhideout View Post
Where might these be found?
lol, yeah um, no.
I think he meant "ignition switch". You can get one at your MC dealer if you want it to be original. I replaced mine since it had a cheap aftermarket style in it, and the new switch was about $40 IIRC. 2 keys came with mine.
You might want to try a bit of spray lube first. The lock tumblers can get moisture, dirt etc. in it and a little lube might just do the trick. Just a short squirt in the hole (don't flood it), or you can spray the key and insert it in the lock hole, doing that 2-3 times.
Jeff
Old 11-12-2012, 06:32 PM
mxhideout's Avatar
mxhideout mxhideout is offline
Boat: '91 PS190, 351 w/'slot
Ok, I'll try some lube first.
My dad is pretty sure that shaft is straight, but the strut is probably bent. Has anyone repaired/straightened one if it has a slight bend?
Also, the shaft has a couple spots that show some wear (you can feel it with your finger). Do people re-condition it, just use it, or get a new one?
Old 11-13-2012, 11:39 AM
TxsRiverRat's Avatar
Boat: 93 Prostar 205
[quote
You can drank em purty but ya caint drank em skinny...
Old 11-13-2012, 11:40 AM
LMFAO - taken out of context, this is some funny sh*take
Old 11-13-2012, 10:05 PM
mxhideout's Avatar
No comment...
Anyone else? Or am I just going to have to make some calls to local shops?... Anyone gotten work done by Propulsion Inc.? (Propfix.com)
Old 12-13-2012, 06:10 PM
mxhideout's Avatar
Well I've gotten a few quotes on upholstery. Viper so far is the cheapest, but I'm still waiting on a reply from Jim the upholstery guy. I hope to get the shaft and prop dropped off this weekend if I have time. When we test rode it, it seemed to run sluggish and on the rich side. Where can I find a cheap carb rebuild kit?
Old 12-13-2012, 07:22 PM
east tx skier's Avatar
MC Hero
Boat: 1998 Ski Nautique
No comment...
If the bend is at the tip of the shaft at the prop end, you are probably not going to be able to have it straightened close enough to the .002" run out tolerance that is recommended. I ran over something with my father in law's MC years ago, bent the prop and shaft up and investigated having it straightened. Contacted a company (in NC I believe) that another member had used to straighten a bent shaft, and when I told them where it was bent, they said it wasn't going to be something they could fix properly.
New shaft from skidim, refurbished prop, some glass work, and I was good to go.
Previous: 1993 Prostar 205
FAQ
Tyler Ski Club
Old 12-13-2012, 07:28 PM
MC Hero
I don't know if it's the cheapest, but it can be your basis of comparison.
Holley 4160 Rebuild Kit for 351, etc.
FAQ
Tyler Ski Club
Old 12-15-2012, 01:15 PM
mxhideout's Avatar
It may be the case, but I still want to take it in to the shop and see what they say. I found some cheaper rebuild kits on summit. How do I know which one it is?
http://www.summitracing.com/search/p...tor-model/4160
Here's a couple tools we made for removing/installing the prop shaft nut/hub:
Removed some material in the socket to make room for the radius on the nut.
Old 12-15-2012, 01:44 PM
MCOCD@13 out of 10
nicely done...
1991 ps 190, mastercraft, prostar 190
