Old 12-12-2012, 05:23 PM
lhkrueger lhkrueger is offline
Boat: Mastercraft 190 Powerslot 1983 351 PCM restored
Platform bolts loose in hole
What has been best practice to restore fit in swim platform bolt holes. Two are stripped and others are close to same. Plastic inserts? Epoxy? Need guidance. Thanks
Old 12-12-2012, 06:29 PM
MCOCD@13 out of 10
You need to get in inside the bulkhead behind the stern and strengthen the joint. What year boat - post pic's please... Lot of stress on holes and bolts so it needs to be done from the inside ...IMO
Old 12-12-2012, 06:40 PM
milkmania's Avatar
Boat: White/Red 91 PS 190
I had the same question.... I'm guessing 83 S&S
Old 12-12-2012, 08:52 PM
sethro's Avatar
sethro sethro is offline
Boat: 1998 Malibu Echelon and 1985 Stars and Stripes
Here is a thread where I fixed the same issue you speak of. I used a backing plate for the top holes and epoxy inserts for the bottom holes.
Old 12-12-2012, 08:54 PM
tph's Avatar
tph tph is offline
check this thread:
http://www.mastercraft.com/teamtalk/...tform+brackets
Old 12-14-2012, 09:54 AM
Yes is 83 S+S. Looked at comprehensive repair thread. Engine out for power upgrade. Will remove fuel tank and open floor to bolster from backside. Need to maintain easy removability so will probably do weldnut style backplate. Anyone use powdercoated steel ilo. aluminum?
