For those seeing rust stains leaking from the riser gaskets, just clean them up, re-surface the mating surfaces using a wire brush or sand paper and just re-install them using new gaskets and a good paste compound.
#12
I will call the dealer, but just out of curiosity...What do new risers and exhaust manifolds cost?
#13
Yep. Some new gaskets with some light sanding will do fine. For fresh water, the risers will last a long time, even if there is rust on outside of the exhaust manifolds.
#14
http://bpi.ebasicpower.com/index.php http://www.skidim.com/ Watch out for shipping charges though, lot's of weight there. Do you have a local retailer? Sometimes they will match the online guys and you'll save on the shipping charges. |
#15
Rusty Risers-Isn't he an old skool porn star?
2002 Blue Prostar 197, 0 Flex Tower, Perfect Pass, and The Preditor-ADHD Skier I'm pursuing my lifelong quest for the perfect, the absolutely driest martini to be found in this or any other world. And I think I may have hit upon the perfect formula :
#16
Well I have bought all the new Risers and Exhaust manifolds.
Only one problem. I can't get the old exhaust manifolds off. I have ground down the bolts but they are stuck on there good. Any suggestions for getting them off??? |
#17
pour penetrating oil on the seam of the mating surface or the 50/50 mix of acetone/atf - let it sit a few hours - re-apply oil. Also apply oil to bolt surface. I would do that for a day or 2. Then get a small steel mallet - and give a few good whacks...IMO Can you post some pictures of how the manifolds look?
Will do. That sounds good. I am amazed at how stuck on they are. I didn't think of the penetrating oil. Will do. at this point the exhaust manifolds are toast. All the grinding we have done has eaten away at them. Still I will post some pics though.
Thank you. |
#19
The next thing I would do is seek the advice of an engine shop...any luck searching the old threads?
..maybe someone will chime in after Christmas... sorry your issue on this... I am sure you are very frustrated. Good luck..
Mike205, is this something that you have done to yours before?
