  #41
Old 05-10-2012, 04:21 PM
jessejames jessejames is offline
Boat: 99 Mastercraft Prostar 205 VRS
Thanks guys. It isn't my Propeller nut. I checked that and it is tight with cotter pin intact. You can hear it coming from the Hurth Tranny. Sounds like rocks like Todd said. I'm going to have my dealer change it out to enginge oil. It needs to be changed anyway. Only reason I'm having them do it is so they can also listen to it to make sure it isn't the damper plate.
Sorry B-Rad, I would and could probably do it myself and normally agree with you, but I just don't have the time to spend on it! Too many other projects going on, working full time and running a small business on the side!
Old 12-03-2012, 04:49 AM
jwp1504 jwp1504 is offline
Boat: Mastercraft, x star, 2000, 330
Hi Guys,
I have a 2000 X Star that has the same problem, rock like sound at idle but goes away at speed/revs.
After reading the forum i was wondering if woodrow had any further input??
Or have we come to the conclusion that it is "normal" and does/will not effect performance??
Old 12-08-2012, 11:42 PM
rem_pss308's Avatar
rem_pss308 rem_pss308 is offline
Boat: 1999 X-Star 330 HP
Send a message via Yahoo to rem_pss308
Mine rattles a little bit. but I had another rattle problem before.
I was sure it was the transmission. but it ended up being my idler pulley. it would rattle in neutral and idle speed. after changing the idler pulley the rattle went away.
You might want to check it. it was a 20.00 fix.
"Let me not pray to be sheltered from dangers, but to be fearless when facing them."
1999 X-star, 330 LTR, Zero FLex tower.
