Old 12-08-2012, 06:16 PM
strad's Avatar
strad strad is offline
wow those exhaust bolts are IN there. . . tips for removal?
I already hit them with penetrating oil (pb blaster). It's not an urgent project, but I would like to address the manifold to riser gaskets and also the rust stains on the manifolds (latter is why I would like to remove them). I'm also a little afraid that I'll have to replace them based on the amount of rust pieces that I got and am still getting out the manifold drains. So yeah, manifold bolts should come out.
I have a two-foot breaker bar, but frankly I'm afraid to put any more torque on it than I have for fear of rounding out the allen holes. I'll probably hit them a few more times with penetrating oil just to see what happens, but would like to have as many ideas as possible.
It's an 84 351 PCM, and I'm pretty sure the bolts have never been removed. So they're in there about as tight as you'd expect lol.
White with blue stripes.
Old 12-08-2012, 06:56 PM
Cloaked Cloaked is offline
Boat: MasterCraft
Originally Posted by strad View Post
.......... the manifold to riser gaskets and also the rust stains on the manifolds (latter is why I would like to remove them).
Is it broken or just not visually pleasing?
A few days of penetrant may or may not do it. Give it a few days but also approach it the way you have been. No more forced torque in my opinion. I'd hate to have to deal with that under less than ideal conditions, when in fact, it wasn't broken in the first place, but I'm also more practical than obsessed with things that make you go "Hmmmmmmmmmmmmm..."
Old 12-08-2012, 06:57 PM
Snipe's Avatar
Snipe Snipe is offline
Boat: Mastercraft ProStar 190 Vortec MX Plus E.F.I.
Try a penetrating oil called "Kroil" that stuff really works. It's a little pricey, but you get what you pay for. I have used it in the shop before retiring, and NOTHING beats it. Just type the word "Kroil" into your browser and it will take you to their site. If that doesn't do it, about the only thing left is heat. Lots of it. Best of luck....
Old 12-08-2012, 06:59 PM
Boat: MasterCraft
+1 on Kroil. I also have it in my shop.
Old 12-08-2012, 07:28 PM
1redTA's Avatar
1redTA 1redTA is offline
Boat: 1981 MasterCraft Limited 351W slot
you could always try some heat
1981 MasterCraft
19' Skier 351W PowerSlot Deluxe
Long gone is the Trans AM
Old 12-08-2012, 08:08 PM
03geetee's Avatar
03geetee 03geetee is offline
Boat: 1983 Prostar 190 Stars and Stripes
I can come down there and yell at it for you, worked a few times.
Seriously keep at it, go slow and if it snaps then it snaps and we re invent a new approach.
JTR
Cream/Red Metal Flake
"Powerslot"
-Charles Chaplin-
Old 12-08-2012, 08:12 PM
strad's Avatar
I may just leave it alone for the time being lol. It's one of those things that would be nice to renew but not at the expense of making a mess.
Just out of curiosity, is it possible to remove the heads with the manifolds installed? The idea being that, if it was possible, in the event I decided to put GT40 heads on I would use new manifolds and not worry about the problem with the old heads. Probably sounds like a newb question but the only other engine I've done a head gasket on, it was possible to remove the head with all the manifolds still installed.
Old 12-08-2012, 08:25 PM
zsqure's Avatar
zsqure zsqure is online now
Boat: MC ProStar 209, 2001, LTR, Blue
Do a google search. Somewhere I read ATF and acetone mixed together in equal amounts works better than most penetrating oils.
Old 12-08-2012, 10:48 PM
Jerseydave's Avatar
TT Hero
^Only if you can get at all of the head bolts, otherwise no.
Try smacking the heads of the manifold bolts with a hammer a few strikes first. Sometimes the shock of the hammer smacking them will help. Good luck.
I was njskier on here.
Old 12-09-2012, 07:17 AM
ctjahn ctjahn is offline
Boat: Own a 78 MC S&S
riser bolts
My riser bolts were a total pia.... but they were not allen type head (standard hex).
3 out of 5 brok off at the head but once I removed the risers I was able to get to the remaining parts. I used PB, Time, hammer, and a tighten, loosen, tighten, loosen technique. (Sounds like you are doing the whole manafold?)
Took me about 2 hours total time but they sat while working on other stuff soaking across several weekends...
Best of luck
Cj
