The low compression cylinder plug looks fine, new according to mechanic.
#22
At this point, I would remove all plugs (I would hope this was already done for the compression test), attach an air hose with 50 psi to the bad cylinder and crank it over manually, to listen for air escaping- if it's coming out the oil filler hole, we'll know it's probably a problem with one or more rings and if it comes out the intake or exhaust, it's probably a valve/gasket problem. |
#24
Has this engine overheated recently, or did the problem start after anything specific occurred?
#25
No known overheating incidents. Unfortunately, I have not owned the boat for long and the only records I have are service records from the past 3 years that do not indicate any red flags or major service.
#26
Are you handy with tools?
Can you take something apart and put it back together again easily? If so then you should be able to do the work yourself and save tons of cash. I would be willing to bet that the engine does NOT have to be pulled. A simple cam swap or head issues can be done with the engine still in the boat.
Rollin' Gangsta Style Quote:
