Old 12-06-2012, 10:29 AM
redraider08 redraider08 is offline
Boat: 2000 Mastercraft X-Star
Drain Plug Location
Hey guys, i have a 2000 X-star with the 310 inmar and am not real sure where the drain plugs are. Below are a couple of pictures i took pointing to what i think may be the drain plug, but it looks like there is some type of sensor at the location on the portside. Thanks for the help!
Old 12-06-2012, 12:20 PM
mwg's Avatar
mwg mwg is offline
Boat: 2001 Prostar 205V
I have an LTR which is the same block; I remove the knock sensor on the starboard side & a brass plug in a similar position on the port side to drain the block. In the first picture, the knock sensor is located directly behind the starter below the plug wires.
Old 12-06-2012, 12:58 PM
dfmaus's Avatar
dfmaus dfmaus is offline
Boat: prostar 205 2000
same for me - I drew in an arrow to be perfectly clear. This is the knock sensor
_________________
2000 SD prostar 205
Old 12-06-2012, 01:12 PM
carlsonwa's Avatar
Boat: 2006 Prostar 197 TT
There should be a plain brass plug on the opposite side then as well.
Old 12-06-2012, 02:50 PM
Thanks for the help, is there any plugs on the manafold that need to be drained? Also, what is the sensor that i had an arrow pointed to in the origonal post? Thanks!
Old 12-06-2012, 04:43 PM
mwg's Avatar
mwg mwg is offline
Temperature sensor (?)..
If I recall correctly (still too early for me to winterize ), to drain the manifolds disconnect the hoses where the join, there should be a hose type connector.
Old 12-07-2012, 10:03 AM
bsloop bsloop is offline
Boat: 91' MC 240sc
Depending on which end of the exhaust manifold is lower, either disconnect the exhaust manifold hoses or remove the plug on the opposite end with a 1/2" socket drive.
To be anal, before reinstalling plugs, I usually take a drive up and down the block once that has hills to shake any other antifreeze out.
I drain, antifreeze, drain, then store. By draining water first, I am sure the AF is not diluted as it passes through.
Old 12-07-2012, 10:49 AM
CC2MC's Avatar
CC2MC CC2MC is offline
Boat: 2005 x-10
I believe he is correct is saying it is a temp sensor as it is right along side the spark plugs. Unplug the knock sensor first then either a 7/16" or 7/8" socket should fit right on it, provided it is the same as my boat. The manifold should have a plug on each end, which in your boat should be forward, if I am not mistaken. It looks like there may be an L connector with a hose coming out of it. See if that hose is connected to another hose from the other manifold. If so, you should be able to unscrew them in the middle and drain the manifold into the bilge. My boat is a direct drive so the engine is turned the opposite way.
