A different filter won't help the -ticking lifter noise on cold engine- problem that's been described here.
A higher quality filter is better for your engine, but it won't fix this problem... IMO.
Jeff |
#22
Gone, surfing. |
#23
I wouldn't be so fast to say that. Anti drain back valves are not all built the same and some filters don't even have them. Letting the lifters drain out can cause noise at start up. This is the case on my wife's van.
Gone, surfing. |
#24
Aside from that, the GM engines referred to in this thread have a vertical mounted filter so they don't benefit from an anti-drainback valve.
Jeff |
#25
OK, don't try a different filter.
Gone, surfing. |
#26
Or, do what some of the GM service bulletins say. Try a different filter. It's just a suggestion and at 5 bucks is surely worth a try, or not. Yes I know the OPs vehicle is an 02.
Service Information 2006 Chevrolet Chevy C Silverado - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 643955 -------------------------------------------------------------------------------- Engine Noise on Start-Up, but Only Lasting a Few Seconds Cause Correction Incorrect oil filter without anti-drainback feature Install the correct oil filter. Incorrect oil viscosity •Drain the oil. •Install the correct viscosity oil. High valve lifter leak down rate Replace the lifters, as required. Worn thrust bearing •Check the crankshaft end play. •Inspect the thrust bearing and crankshaft. •Repair or replace, as required. Damaged or faulty oil filter bypass valve •Inspect the oil filter bypass valve for proper operation. •Repair or replace, as required.
Gone, surfing. |
#27
Changed my Tahoe oil/filter this past weekend, ended up with a Napa Silver filter as they didn't have a Wix for my application (not sure where the Napa branded filter lies in the quality scale or if it has the drainback feature). Also changed to 20W-50 oil. It helped, but didn't eliminate the noise issue. A bit strange, but now it starts and runs silently for about 30 seconds, then has 'the noise' for about a minute. It isn't as loud, nor for as long, as it was. Before, noise was apparent immediately upon startup. Sometimes I thought I had a diesel under the hood. Having an engine that is'full' of oil also probably helps as my rear main seal drips.
1988 Tristar 190 Sport, 351W w/GT-40's, 1:1 Velvetdrive |
#28
I'm glad you at least have some relief and indeed a change in the behavior of the tick. I would not give up complete hope on the filter oil combination. While it may not be a complete fix for everyone I have seen it work more then once. I've also heard of people running half a quart of marvels mystery oil for a couple of oil changes as well.
Gone, surfing. Last edited by CantRepeat; 12-13-2012 at 07:17 PM. |
#29
#30
I bought the 6.0 out of a 2500 (same engine base as 5.3) for my drag car project. Was told it had a noisy lifter. I pulled it apart because I wanted to put a bigger cam in it anyway, and to our surprise, a chunk was missing on one of the stock cam lobes. Hopefully yours isn't that bad, but I just figured I'd post it here since we're talking about it.
