Old 11-27-2012, 09:07 AM
BrooksfamX2's Avatar
Boat: 2007 MasterCraft X2
I got my two 4.5" Mastercraft pop up cleats from ebay for about $50.
MISS "B" HAVEN
2007 X2, Indmar 350 MCX
OJ 13.7 x 15.5
2006 F150 SCrew Puller
http://www.crowniehq.net
Old 12-04-2012, 11:37 AM
bsloop bsloop is offline
Boat: 91' MC 240sc
This whole thread is full of mis used words.
A person can use the term "bumper" but lose my respect for their seamanship.
I also have not seen any examples of "pop up" cleats.
Pop up cleats are spring loaded and release with a button push or pressing on the cleat itself which then "pops" up.
Most cleats are simpler "pull up" cleats that are cheaper and require less fiberglass cutting.
Pay attention to the sub assembly as some pull ups can be require more extensive cutting.
While the pin cleats look petite and sexy they have drawbacks. First, inexperienced and "distracted " people may mis the hole and scratch/chip the gunwale
It takes almost as much work to install a pin or mushroom but they only perform a single function vs a regular cleat that can also serve as a mooring point. (one may consider a few layers of fiberglass reinforcement as the sides are not built up as strong as top sides and corners)
On top of all that, they are usually more expensive, especially the vanity MC logo.
Any of the above choices are probably better than the cheap and un reilable fender hangers.
Personally, I am a fan of the Big B style fender that can be raised higher and offer better protection than the eye style that hangs lower and takes up more space. The low freeboard fenders may have a limited advantage in pier dock applications where there is not as much solid side structure for the fender to contact and a greater chance of the boat slipping under.
Old 12-04-2012, 12:46 PM
And misspelled words.
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
WEEKEND WHEEL SPECIAL
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
Old 12-11-2012, 04:23 PM
chunter's Avatar
chunter chunter is offline
Boat: 1999 Prostar 205
you all might like this
http://www.marinepartdepot.com/new316ststqu.html
