Ski and Wakeboard Off Season Storage Racks
I am in the process of figuring out a storage rack for our various ski's and boards. I am looking for some inspiration, post up pics of your off season set up.
http://www.wakeworld.com/forum/showthread.php?t=787640
all types of ideas here. I just use standard L brackets for shelving and bent them a bit upwards. Also home depot sells some "bike racks" that anchor to the wall. These work really well for boards. They have a hook to use a bungie cord to keep things in place if you are worried about bumping them. 5 bucks a piece if I recall and you don't end up with a ton of wood on the walls. http://www.homedepot.com/catalog/pro...806704_300.jpg |
Board Rack
I made this out of about $18 worth of parts that I picked up at The Home Depot. It works really well for our purposes. I drilled the 2x4's about half way through to place the dowel into. I then screwed it in from the back and side after glueing with wood glue and attached the whole thing to studs using 4" lag screws. I am pretty sure it is strong enought that I could do pull ups on it but I am not willing to try.
There is a thread here somewhere about this............
MISS "B" HAVEN 2007 X2, Indmar 350 MCX OJ 13.7 x 15.5 2006 F150 SCrew Puller http://www.crowniehq.net http://banners.wunderground.com/weat.../OR/Albany.gif |
Here's mine:
Before..... ![]() After....... ![]() |
here's mine.... adjustable shelf brackets with foam pipe insulation on them to protect the boards.
MISS "B" HAVEN 2007 X2, Indmar 350 MCX OJ 13.7 x 15.5 2006 F150 SCrew Puller http://www.crowniehq.net http://banners.wunderground.com/weat.../OR/Albany.gif Last edited by BrooksfamX2; 12-04-2012 at 07:37 PM. |
I went quick, cheap, and easy. Got this from Overton's. It suits my garage since it lays flat against the wall. We have 4 wakeboards and 2 sets of combo skis in it. Basically two straps with many adjustable buckles, and two hanger hooks.
Ladder-Rack-Waterski-Storage-System
Jeff |
Brooksfam - That is a great idea!! All of the brackets would then be height adjustable for each board type.
Blue Hawk racks from Lowe's - about $7 each.
onewheat 2007 X-15 |
Mine, built to the wakeworld DIY specs...
1991 ProStar / 351W with 1:1 Velvet Drive |
