Old 11-30-2012, 10:07 PM
jfw432 jfw432 is offline
Boat: other
Piston problems
I pulled this engine because I was replacing the floor in my boat. The engine ran great, had an 8 psi split between the highest and lowest cylinders in a compression test, and all cylinders passed the leakdown test. Since I pulled the engine, I decided to give it a quick look to see if it needed any attention.
After cleaning a lot of carbon off the pistons, I found two pistons that had some damage. Are these pistons useable? If not, can I just replace the two pistons or do I have replace them all?
Old 11-30-2012, 11:23 PM
EricB EricB is offline
Boat: 77 S&S, 1983 S&& PS, and now a 98 Anniversary S&S LT1 PS
Interesting....
Top pic looks like some sort of solid small object made dimples in the piston. Second one looks like some sort of erosion caused by detonation or coolant/water.
While there may be some irregularities on the tops of the pistons, it really is the damage and wear to the sides of the pistons and the condition of the cylinder block bores.
Does the top ring of the piston(s) rotate freely? Any other abnormal marks in the bores? Any marks in the cylinder heads (of the corresponding cylinders?). If not, those pistons are re-useable. Any other suggestions would require additional information.
You already have the heads and pan off, so how far are you going? If the engine ran fine and compression was good, what made you decide to go after the internals of a good engine? Might as well rebuild now....
Old 11-30-2012, 11:32 PM
wheelerd's Avatar
wheelerd wheelerd is offline
Boat: 2005 X2
How many hours on the engine? Are you the original owner or do you at least know the history of the boat?
If it was running fine before and everything else checks out, perhaps a really light hone job on the cylinder bores and new set of rings and put it back together. I wouldn't touch much else.
Do the crank journals and con rod bearing shells look OK?
Old 12-01-2012, 01:21 AM
Boat: other
Well I pulled this engine apart because it was leaking a significant amount of oil and has roughly 1000 hours on it (to the best of my knowledge). After 2-3 days, there would be pooled oil in the bilge. I don't really know the history of the boat but it's had some neglect for sure. So between those three things, I figured the engine could use some lovin'.
The condition of the heads are fine and the ring gaps in the pistons appear to be undamaged. The cylinder bores aren't perfect but a good hone should clean most everything up. The taper isn't too bad. The worst cylinder bores aren't from these pistons though. My plans was to find the source of the oil leak and certainly replace the oil pump while I'm in there. The rod bearing were ok but the crank bearings were gouged up some. The rods and the crank still look decent though but I haven't measured them yet.
I was curious as to what my ring gap was after all these years so I measured 4 rings in their corresponding cylinders...I didn't think about it for the first 5 cylinders. Anyway, the cylinder with the detonation looking marks on it had a 1/4"-1/2" piece of one of the rings broken off. Yet that wasn't the worst cylinder in the compression test.
Here is a picture of the side of that piston with the detonation looking marks on it.
Old 12-01-2012, 07:24 AM
CantRepeat's Avatar
Boat: No Boat
Well you found what dinged up the top of piston right there.
I wouldn't reuse any of those pistons at 1000 hours. If you are going to rebuild it might as well go 30 over and get the block cleaned up. You should probably go 10/10 on the crank too.
Tim
Old 12-01-2012, 09:28 AM
JDC's Avatar
JDC JDC is offline
Boat: 2004 Prostar 209 - MCX
I'll echo Tim's comments and say I would not reuse those 2 pistons. Replacing 2 or all 8 would depend on your MCOCD level.
You've come this far... add a few hundred $ in parts and do it right.
Jeff
Old 12-01-2012, 10:32 AM
I'm with Tim on this also, assuming funds are there to get the it done. A proper job done now should give you another 1,000 hours of trouble-free service.
Old 12-01-2012, 10:51 AM
Boat: other
Ok well the rod, crankshaft, and cam are within spec with room to spare so I don't really see any point in touching those. Ring gaps after honing are around 0.025" on the first ring in the middle of the bore which I can see being a hair big for a mostly stock engine but would that really justify an overbore?
Old 12-01-2012, 10:58 AM
Rossterman's Avatar
Boat: 2001 prostar 205V
If bores are good, hone and put in new pistons and rings along with rod and main bearings. Parts are pretty cheap for these engines and aren't marine specific.
Old 12-01-2012, 11:07 AM
I luv the OCD... since I pulled the engine to fix the floor..I decided to disassemble the engine... If you know what your doin' it probably doesn't seem like a big deal...I for one am impressed and admire with those who have the confidence to rip down an engine and then put it back together... let's see the man cave where the work is being done
