Thermostat Replacement--gasket sealant or not?
Hi all,
Replacing the thermo on my '07 197TT with 5.7L MCX. Do I use liquid gasket sealer or not? I've had conflicting info on this and am looking for experienced perspectives. Many thanks in advance for your guidance.
"This one goes to eleven." 2007 ProStar 197 TT w/MCX and Powerslot. |
I use a bit of sealant because I had some pitting on mating joints on my 1995
Same here... Mine was pitted pretty bad. I tried a new gasket first and it leaked like crazy. I had to use a lot of sealant to make it seal up. I guess it depends on the condition of your manifolds.
Thank you guys. . .sealant it is!
Coat each side of the gasket with gasket sealer
2006 Maristar 200VRS MCX KGB Ballast and all the works! Tow Veh: 2010 Toyota Tundra Bike: 2007 HD Street Glide Beer:Sam Adams Boston Lager/ Cherry Wheat, Petes Strawberry Blonde, Petes Wicked Ale Chief Petty Officer: "Results not excuses" "You Can't Beat a Tree" |
this is how my monifolds looked for my t-stat after I cleaned it up
Again, thanks for the confirmation. I think my old gasket must have had a tiny leak as well. When I pulled the manifold, one of the two bolts came out with a lot of rust dust in the threads. Likewise, the threaded hole was full of fine rust dust (the hole on the right in the picture). So, the good news here is that I pulled it now--otherwise, the bolt may have eventually rusted beyond normal extraction. Lost of WD40 to displace the rust, and back together it goes!
*Bump*
five months ago, I removed my thermostat due to an never getting warm engine. Finally got my new thermostat but I forgot where the old one was fitted? It can be mounted in the upper and the lower housing. It is an MCX year 2004, no closed cooling. Anyone please? |
You need to mount it in the upper housing if it's a marinized engine OTHER than the LT-1. |
If you use a gasket, and there's no reason not to, coat the bottom, stick it in place and let it sit for about 1/2 hour. Then, put an even layer on the top, place the housing on (preferably with no hoses, to it sits evenly) and press it lightly into place. Thread the bolts in but don't tighten it. Let it sot for about 1/2 hour before tightening them fully and don't run it for a few hours. I had problems with my cars and trucks with leaking at the thermostat and doing it this way cured it.
