Old 11-22-2012, 07:42 AM
davidstan's Avatar
davidstan davidstan is offline
Boat: 2008 X2
Draining block
Will leaving the cooling system full of lake water over the winter be harmful if you know you will not have freezing temps to deal with. 5 months the boat will sit. Thx
David
2008 X2 MCX
1999 Maristar 210 (sold)
1996 Bayliner 2050
Old 11-22-2012, 08:18 AM
Considering the little time and effort required to drain and winterize an engine (the basics), I can't see why you would want to take the chance. If it was mine, I would definitely drain and fog it.
Old 11-22-2012, 08:25 AM
davidstan's Avatar
Boat: 2008 X2
The x2 is at a lake home garage connected to the house and boat is very difficult to maneuver and tower is down so it is not easy. I failed to put in my first post "I know,I know, I know it is better to drain it" but that wasn't my question.
David
2008 X2 MCX
1996 Bayliner 2050
Old 11-22-2012, 08:58 AM
Unless you can be absolutely sure it can't possibly freeze, under any circumstances, go ahead. You didn't post anything about the tower, garage, etc, so I based my answer on easier access but if you don't want a bad wake-up call in spring, I still recommend draining it.
Old 11-22-2012, 09:09 AM
Jerseydave's Avatar
TT Hero
Besides risk of freezing, I would think that water in the system would promote internal rusting of the engine....that's why I always drain mine and refill with -60 West marine anti-freeze. It has corrosion inhibitors in it according to the label.
JimN, curious on your thoughts about leaving block drained vs filling it with a/f?
I was njskier on here.
Old 11-22-2012, 09:21 AM
MCOCD@13 out of 10
Did some research on this this year and you could do a number of things if your concerned with corrosion. #1 - the moment water touches iron/steel it begins to rust. There's only so much oxygen dissolved in the water and after a certain period of time the rust reaction would stop. #2 - You could run some "Evaporust" thru your cooling jacket and let it sit overnight. It's non-corrosive and gasket safe to remove rust from your water jacket. It's pricey but it works. 5 gallons will cost you about $100. I like it because I believe it will keep the water passages clear. I also now wet store my block because of the corrosion inhibitors.
That being said - once you drop her back in the water the rust cycle starts all over again. I would to buy aluminum exhaust manifolds and risers - but the price so high.
JimN - which year has an aluminum block and heads?
Old 11-22-2012, 09:28 AM
Cast iron rusts and there's not a thing we can do about it. Even if it's filled with A/F that has rust-inhibitors, it still rusts because the A/F has water in it but the first time fresh water goes in after the winter, the rust is flushed out. With water left inside, there's a lot more corrosion going on. My jointer lives in the garage and I found out the hard way that I didn't wax the table when I winterized my table saw, planer, bandsaw, etc. The next time I uncovered it, I saw that the cast iron top was completely coated with rust and this reminds me- once it warms up today, I need to go out and wax the table saw and bandsaw tables.
Old 11-22-2012, 09:30 AM
LT-1 is the only engine MC used with aluminum heads, AFAIK. The plenum on the LTR is aluminum but I'm pretty sure there's no water passing through it.
Old 11-22-2012, 09:33 AM
MCOCD@13 out of 10
Thanks JimN...I hear ya on the tools in the garage...had to do the same thing...dang rust!
Old 11-22-2012, 10:01 AM
I was pretty PO'd when I saw it. The problem was that I needed to use it at the time and it took 3 hours to finish getting rid of the rust without screwing up the surface.
