Old 11-20-2012, 04:14 PM
jschildm jschildm is online now
Boat: 1998 ProStar 205
As long as the glow plug is still threaded in, I don't see how it would run rough permanently. The relay only stays on 2 min, and then none of them do anything. It doesn't sound to me like that is the Ops issue.
One other quick thing that you can do without any fancy tools is unplug the ICP sensor on the driver's side High Pressure Oil rail. It will then go to a default value, and if it runs OK unplugged, then the sensor is the issue.
Old 11-20-2012, 06:29 PM
mdo817's Avatar
mdo817 mdo817 is offline
Boat: Mastercraft Skier 1984, 351 PCM
First thing I would check would be your engine oil. Stupid as it sounds if it is low it will do exactly what you are saying run but run rough with little power.
Sent from my DROIDX using Tapatalk 2
'84 Stars and Stripes
Old 11-20-2012, 10:14 PM
mtajpa's Avatar
mtajpa mtajpa is offline
Boat: MC 1999 Maristar 230 sport
+1 on the OIL and Fuel Filter. These are the first thing to check. If you have been doing general maint. then you may rule this out.
However one thing to look at maybe your valve cover gaskets. These gasket actually have the injector connetors and the glow plug connections in them. The connections are known to burn up especially if your have been cycling the key to increase the glow plug duration.
Check this out and you will see what I am talking about.
http://www.youtube.com/watch?v=pJ1wyMBvLLc
99 MariStar 230 Sport LTR 330
Old 11-21-2012, 08:16 AM
Both of the above mentioned are great places to start. I was just thinking last night that you might check the oil level in HPOP reservoir prior to starting as well. It could be leaking down.
Old 11-21-2012, 08:28 AM
76S&S's Avatar
76S&S 76S&S is offline
Boat: 2002 X Star Sold -76 Stars & Stripes, 351, custom platform
Oil level is good and recently changed. I don't think it is the injector connector as when they work loose you usually loose that entire bank (side) of the engine.
It was dark when I last started it and I did notice smoke but couldn't see the color.
I think I'm going to pick up an infrared thermometer from HF, start the motor and check the temps on each cylinder. This should narrow it down. Assuming I can narrow it down to one cylinder, then I will pull the valve cover, start the motor and unplug the injector to see if it stumbles or if there isn't a change. If no change, I'll look at replacing the injector.
Thoughts?
New interior is in, now it's time to get on the water
2002 X Star
Sold - 76 S&S
Old 11-21-2012, 11:41 AM
TayMC197's Avatar
TayMC197 TayMC197 is offline
I think its a good start.. It really doesn't cost too much to have the injectors checked. Normally about 100 bucks to have someone run a diagnostics. Saves a lot of guess work.
Old 11-21-2012, 02:42 PM
76S&S's Avatar
Tay, I just saw where you blew your turbo, sorry to hear that.
I have a turbo on a "cough, cough" pwc that needs rebuilt. Where would you put the job on the difficulty scale?
2002 X Star
Sold - 76 S&S
Old 11-21-2012, 06:52 PM
mtajpa's Avatar
Thoughts?
The valve covers have 2 connectors on each cover. There are 2 glow plugs, and 2 injector connectors in each connector. You can have a single injector connection fail inside the valve cover. You maybe able to use an OHM meter and read the resistance from the injectors to ground.
Old 11-22-2012, 12:14 PM
TayMC197's Avatar
Getting it out and back in is the hard part. Rebuilding it on a level of 1-10 would be about a 3. It's not too difficult. I believe you have the waste gate on your turbo so that will make it easier. Don't let it intimidate you, it's not complicated, just tedious at some points.
Got mine out and found that my variable vanes are shot. So I'll actually need an entire new turbo. Got it on order, should have it back in next weekend.
Old 11-26-2012, 10:25 AM
76S&S's Avatar
That ***....
2002 X Star
Sold - 76 S&S
