Old 11-16-2012, 02:56 PM
Miss Rita's Avatar
lifters?
My '02 Tahoe only has 53,000 miles. For the past year the lifters make noise when started in the AM, gradually goes away after 1-3 minutes. A mechanic friend suggested switching to Valvoline in place of Pennzoil, didn't help.
Question #1: Is this a problem? (I'm guessing not)
Question #2: Any easy fix that I should try?
Old 11-16-2012, 03:16 PM
MCOCD@13 out of 10
Which engine do you have...How do you know that it's the lifters making the noise? did mechanic use stethoscope?
Old 11-16-2012, 03:17 PM
1redTA's Avatar
1redTA 1redTA is offline
My 08 Sierra with the 5.3 does it sometimes it got better when I switched to AMSOIL but will still do it if the engines oil gets low ( the engine consumes a quart every 9,000ish miles ) it doesn't bother me though
1981 MasterCraft
Long gone is the Trans AM
Old 11-16-2012, 04:42 PM
Miss Rita's Avatar
It's the 5.3. No stethoscope was used. We're thinking it's a lifter because it only happens after a cold startup. Once the noise is gone after a minute or so it won't be heard again until after the vehicle has sat for a while.
Old 11-16-2012, 06:19 PM
clrussell's Avatar
Boat: 1990 mastercraft p190
I want to say there is a problem with the oil pickup tube o ring where it goes into the pump on some of those engines. My 6.0 had that problem and they are basically the same engine.. Does it run bad when it does it or just rattle? I would think if a lifter was loosing prime it would miss on a cyl while rattling.. I think they are hydraulic roller lifters, keep in mind I'm just thinking there. But that's basically all it could be on the top end
Tapatalk
Old 11-16-2012, 06:59 PM
neil.anderson63's Avatar
Boat: 2007 X2
Had an 02 GMC -At about 45K miles the ticking started at cold start up then went away when engine warmed up. Tried the different oil... no luck. Replaced ALL of the lifters and the ticking went away. Sold it in 2005 with 75K miles and no ticking.
Old 11-16-2012, 10:19 PM
JDC's Avatar
JDC JDC is offline
Boat: 2004 Prostar 209 - 350 MCX
2000 Silverado - 5.3L
Mine has been doing it for 4 years, only on cold start, for about 1 minute. A friend has the same engine and his has been doing the same since 2004.
It bothered me for the first year but now I don't care.
Jeff
Old 11-16-2012, 10:34 PM
jhall0711's Avatar
Boat: None
This is very common with both the 4.8 and 5.3 vortec V8s. It was a tolerance issue in some of the early years and was supposedly correct in 04. There is a lot of threads about this on silverado forums. Most have just accepted it as normal. I have a 04 Silverado with 5.3 and never hear it.
Old 11-16-2012, 10:38 PM
Nick911's Avatar
Nick911 Nick911 is offline
Boat: 2013 Mastercraft X25 on order, 6.0 Ilmor, Pro Package, slammed and flaked!
I've had two Silverados with the 5.3 am they both do this. My Yukon with 6.2 does it as well. I'm told it is common with all GM engines. I add 2 cans of Wynns Engine Tune Up after every oil change and it helps.
Old 11-16-2012, 10:41 PM
Aric'sX15's Avatar
Boat: 2010 Mastercraft X15
Had a 2007 Silverado with the 5.3 did it every cold start up since ive had it. bought it new and it did that noise for as long as i can remember. Never was a problem.
2010 X15
