Old 11-09-2012, 10:06 AM
mybobtail mybobtail is offline
Boat: x14
Starting boat out of the water
I put my 3 hours old 197 into the water today drove it the length of lake about Halve a mile
then drove back with a skier got to end started to turn then the temp light came on I noticed high temp switched off motor straight away .i ph dealer and it's going in first thing Monday.
what I want to know is does anyone start there boat before they put in water. I don't run the motor I just turn key soon as it turns over I switch it off.only because the first time I put my x14 in the water the battery was flat. after that I did it every time with the 14 had no probs.
the dealer said I might of burnt out one of the pick up blades. and I not suppose to do it.
but I did it with jet ski and the X14. the guy that runs the lakes said last year it happen to a brand new Malibu so he said it not uncommon
Old 11-09-2012, 10:22 AM
KelownaX45 KelownaX45 is offline
Boat: 190, x45
We never start the engines or turn the motors over out of the water. I will back the trailer up enough to get the pick-ups wet and then fire them up, then power off the trailer. If you have a bad battery, no worries, your still on the trailer and not flotaing anywhere.
Old 11-09-2012, 10:26 AM
jdl xstar's Avatar
jdl xstar jdl xstar is offline
Boat: '07 MasterCraft X-Star L18
Something certainly sounds wrong with the water intake but I wouldn't be quick to assume its because of turning your engine over for a couple seconds out of the water. Did you ever drive through weeds or a shallow area so that you could have sucked up some gunk?
If my boat has been sitting for a couple weeks or more, I always turn the engine over (much to my neighbor's chagrin) for literally 1 second to make sure the batteries are good. So don't feel bad about doing that and i hardly think that a second of spinning dry can damage the impellor. In terms of boating, few things are worse than getting to the dock and having dead batteries. good luck
Old 11-09-2012, 10:38 AM
mzimme's Avatar
mzimme mzimme is offline
Boat: '83 S&S w/ PowerSlot
If you fired up your boat without hooking it to any water source, especially after having it sit for any extended period of time, you probably didn't break just 1 vane from your impeller, but you probably broke every one of them off instead. NEVER, EVER, EVER, EVER, under any circumstance start your boat without it being in the water or hooked up to a hose. The impeller vanes are rubber, rubbing against a metal housing. They burn up and break off very quickly when they start spinning while they're dry, and they start spinning as soon as the starter starts trying to turn the motor over. If you started it for the first time after sitting all winter, the rubber impeller had also probably began to seat to the metal housing, making it even harder to spin and break loose on the first start while dry. Impellers need to be lubricated, and water is their lubricant. It's like having a prostate examination with no lube... you wouldn't like that would ya?
The good news is, you could fix this yourself for the cost of an impeller at www.skidim.com instead of paying for what will probably end up being a 500+ dollar dealer visit. If you decide to do it yourself, be sure to go through all the hoses after the impeller housing up all the way to your thermostat, because that's more than likely where all of the vanes you broke off are piled up at.
Old 11-09-2012, 10:46 AM
Boat: x14
hi thanks for the replies so far. just to let you know I am in oz so we are starting our summer .and the boats brand new I took it out 2weeks ago and then again today .so it hasn't been sitting .
we checked underneath and there was no weeds etc near the intake .
Old 11-09-2012, 10:50 AM
ski/hunt's Avatar
ski/hunt ski/hunt is offline
Boat: 96 PS205
Check for stuff at the trans cooler. Lots of small stuff can clog the small openings in there and reduce the amount of water the engine will get.
Oh and don't start dry or get P-exam without lube!!
You haven't lived until you grab a wild hog by the legs when a dog is holding him by the ear!!
Old 11-09-2012, 10:51 AM
Ski-me's Avatar
Ski-me Ski-me is offline
Take a look at your impellar and see what kind of condition it's in.
- Jeff
1994 205, LT1
Old 11-09-2012, 11:07 AM
jgraham37128 jgraham37128 is offline
Boat: 2010 Mastercraft X2
Starting
My dealer started a new boat in the showroom and man did it sound sweet! I personally never start it out of the water. I do exactly what someone else recommends I leave it on the trailer and back it off in reverse. I don't like the push off the trailer due to anything can happen and if it's still on the trailer you really don't have any big problems. (leave the plug out and etc..)
I'm going to bet it's not the impellar, I think it's something else.
Let us know what you find.
JG
Old 11-09-2012, 11:08 AM
Summer
And wow, I sure wish it was summer here!
Old 11-09-2012, 11:12 AM
MC Platinum
Simple answer is it sucked up some weeds and the transmission oil cooler is clogged. Easy fix, and something a person should do as preventive maintenance a couple times a season.
And yes, you can start a boat out of water and not see any immediate issues, but this will catch up with you with shortened impeller life and potentially an overheated boat on the water.
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
SPECIAL PRICING CONTINUES
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
