  #121
Old 08-30-2011, 02:04 PM
gatorguy's Avatar
gatorguy gatorguy is offline
Boat: 1997 PS205, x-14 someday
Originally Posted by krutzmart View Post
I cut out a spot in walk thru for subs. The best way to get sound out from under dash.
I made a trim panel to cove it up.
Do you think you lost any hull rigidity? Is there any reason not to do this? I have thought about doing the same thing, but hate to cut big holes in things that are hard to put back.
Old 08-30-2011, 04:53 PM
krutzmart krutzmart is offline
Boat: X Star
I still hit double up's and big surf wakes, no issue's here.
My friends nautique had an access door to get to a cooler years ago and I got the idea from that.
I don't think I have lost any integrity in the hull or dash for that matter.
Give them a few years and it will be an expansive option....
It sounds great....
Old 08-30-2011, 05:06 PM
Boat: X Star
Oh,
Be sure to use lock tight on everything. I over Kill it, stainless steel everything, lock wax nuts with lock tight.
This will help prevent those loose screws from the vibration.
Old 06-06-2012, 01:39 PM
BriEOD's Avatar
BriEOD BriEOD is offline
MC Platinum
Boat: 2000 MasterCraft ProStar 205 DD
I have been meaning to post this photo.
Old 06-06-2012, 02:34 PM
JRW160's Avatar
JRW160 JRW160 is offline
Boat: 2003 X2
12 polk 6 1/2's with tweets, 4 12" alpine type x subs, 1 audiobahn 2400 on speaks, and audiobahn 1200 mono on the subs
Rockford 10 fared capaciter
Alternator upgrade to 140 amp and may go to 200 amp soon
Need more batteries........Maybe a fork truck battery would work ? JK
Is that all black vinyl in the boat?
2003 X2
Old 06-06-2012, 06:20 PM
brucemac's Avatar
brucemac brucemac is offline
Boat: 2003 Mastercraft X-2 MCX
looks good Brian! hope you have a great season!
¡Viva 205v!
2003 X-2 MCX
Old 06-10-2012, 09:21 PM
ZachDaddy's Avatar
ZachDaddy ZachDaddy is online now
Boat: MasterCraft, X15, 2007, MCX, Acme 5 Blade, Pair of WetSounds Rev410's, WetSounds SD6, 2 JL 12w6v2 subs in sealed box, JL HD750/1, WS402SQ
This is our setup: A JL 12w6v2 in a sealed box with the old free air sub as a vent. I'm using a JL 750/1 amp this year. I'm searching for a bass reflex or ported box that would fit in this area but it just to small. I could put a second sub in the passenger compartment like the Xstar did a few posts back. The sub hammers but I'm waiting for the Wetsound XXX v2 to get a little time out in the world before I make anymore changes.
Old 11-03-2012, 07:49 PM
SkiMor's Avatar
SkiMor SkiMor is offline
Boat: 98 Sportstar
Looks good. Thanks for the ideas guys.
Old 02-25-2013, 09:30 PM
Theclarks1111 Theclarks1111 is offline
Boat: 2007 Mastercraft X2 350
Just stumbled upon this, I know its old. I wanted to find out what type of distribution blocks you used for this setup. And where did you find them. Thanks.
Originally Posted by X-Aggie View Post
This is my old setup: 2 JL 10W6v2D4's in sealed Line X Coated Boxes, and 1 JL 13W7 in a sealed Resin coated 1in Plywood box. 1 1000/1 on the 13W7 and another split between the W6's. Pictures are pre Line X and grills.
Old 02-27-2013, 03:43 PM
dvsone79's Avatar
dvsone79 dvsone79 is offline
Boat: '99 ProStar 205V
12" Polk audio sub in a ported box that my brother had lying around, not in use, so he donated it to a good cause. Carpet doesn't match and it takes up a lot of space, but it makes up for all that and then some when you hear it!
