TBI engines, especially from the '90s, don't have a crank position sensor, they use the can on the distributor shaft and, unlike crank sensors, that doesn't tell the ECM which direction it's turning. The ECM uses the MAP sensor to detect engine load (uses barometric pressure and engine-induced vacuum relativee to RPM and throttle position), TPS detects idle throttle position (</= 2%) run throttle position (>2%) and fast throttle position changes (delta ±>20°) for acceleration enrichment or deceleration enleanment, and coolant temoerature to determine whether to add or remove fuel when it compares its state, relative to the fuel mapping tables in the program. These run rich enough that changing the lobe shape won't cause the engine to experience problems unless it's run really hard and something is outside of the normal ranges. |
#12
Hi,
so driving for barefoot, there is a slight change of experience problems with roller cam and original EFI computer? Ok, nothing should be out of normal range, except the cam (the not original roller cam was included in your reasoning). Also cooler air temp. in Finland, but this EFI does not straigth take that into account? Or, as you said rich enough; If we know the max. output of the original EFI, we could calculate what is the base GM engine's max. requirement? Or are these specifications publicly available? Something should exist at least. BR, Pasi
PS190 1995 5.7 l EFI TBI 1:1 13x13 4-blade prop. Barefoot boom, wakeboard boom & fatsack. UK made trailer |
#13
Temp.
Hi, my barefooting driving is rarely 38 mph (US nautical miles), more likely in 35 -36 mph range at the highest. By the way the old engine (ca. 2100 h) still this summer took close to 38 mph, before it broke down. Cooler air is more packed, i.e. more oxygen in smaller space, you get more power then actually? Maybe with TBI, high revs and constant resistance for the engine with previously described barefooter causes something? Though I understand no major problems. My altitude where I normally ski would be ca. 102 feet above sea level. Occasionally at around 246 feet. BR, Pasi
#16
Hi,
any estimate, how much base engine with roller parts and new intake manifold would increase fuel consumption? Likely to be not less consumption. I mean more hp, vents longer time open, but less friction, newer engine. + / - = 0? BR, Pasi
#18
Dont think you will see much change. Tbi predator engine is essentially what you would have and they are very good on gas. Better combustion and less friction with roller cam and rockers = better fuel economy.
#19
Ecm
Hi,
any idea what exactly is the ECM on this original engine? Maybe some codes on the ECM will tell. I have replaced that many years ago, as the original broke itself, had to order a new one from MC UK. The boat with original ECM had starting problems with warm engine since new, I experienced that a couple of times, but not anymore after replacing the ECM. BR, Pasi
#20
Hi,
Roger from Michigan Motorz told me not to take an engine with a roller cam. "TBI 5.7L engines and the ECMs are very finicky and do not like any changes or modifications. We know from experience." The engine might not run properly.
