next couple of days Concern
Guys,
after getting everything I needed from the lt1 checklist I had all intentions of winterizing today. The forecast had a different idea, steady rain all day. Well the next couple of nights they are saying mid 30's. Ive seen some forecast say 32 and some 35. Question is what sould I do. Boat is in a open in the front only carport, is this a must do today no matter what the weather is? could i put a heater in the carport to keep a little heat in there? |
FWIW, when the winterizing season ran long/winter came early, we were out there in all kinds of weather, including rain and snow. If it can be put under a car port, why can't you do the whole thing? |
the carport has very little working room and low height clearance. Its on a slab with block on all sides but front not really where a want have it running dumping water in there for several minutes.
drain and walk away. Nothing will improve after that point. Button it up later when you finally make yourself do it (..........how long has this been coming? )Stick a shop light or any 75 watt bulb (energized) under the engine cover. Personally, I would not worry about a predicted 32 deg F in your area. I have yet to drain mine and won't give it a second thought at 32 deg F near Knoxville in the lower elevation. .
93 190 . Hypocrites, boot lickers, and crybabies…the world is full of them…. just look around - near-by . Duraflap / Kaydenco aren't worth a hoot Hose picture (internal) http://www.mastercraft.com/teamtalk/...68&postcount=8 . Last edited by Cloaked; 10-28-2012 at 01:02 PM. |
The shop light is cheap and a good insurance policy. I do it anyway in he cold
I've heard that it takes 29 degrees for 3 days straight to pop the freeze plugs. Don't forget that if it's 50 degrees during the day, the massive engine block will hold some of that head into the night.
I wouldn't lose a wink of sleep about a night of 32, or even a week of 32 degree nights (as long as it got into the 40s during the day).
See my on-going 1987 Prostar 190 "project" thread here! |
thanks guys, I really thought it would be ok for a night or two just wanted to hear it. My first ownership of a mastercraft and inboard so I need to get to know it. So i went ahead and removed manifold plugs and block plugs and all lowest hoses. Man this site has helped me soooo much.
