Old 09-30-2012, 05:29 PM
wbhobbs wbhobbs is offline
Boat: X25 2011 350 Indmar
Shower Temperature Problems 2012 X25
I have a 2012 X25 with a shower - the temp varies substantially VERY hot to rather cold. Next time i'm out in the boat I am going to look at the temp vs RPM and Engine Temp to see if i can detect a pattern.
I have the 5.7 Illmore, it's a factory shower - and like a few others, I'm not thrilled with the kitchen faucet looking knob to adjust the temp- it's too easy to bump - and if I toss a fat sac in the back storage compartment there's no way the temp is not going to get "readjusted"...
Regardless, the temp changes erratically. I have had a Heatercraft shower in the past on other boats with no problems at all.
I suspect it may be the Illmore thermostat - they seem to be set to run across a wide range - maybe 130 to 155 degrees. The factory doesn't have a solution.
Is anyone else having a similar problem? Any solutions?
Old 09-30-2012, 06:05 PM
MASTIQUE's Avatar
MASTIQUE MASTIQUE is offline
Boat: Past: 1986 MC 19 Skier; Nautique, 230, 2009, PCM 343; Current: X-45 ZFTP5, ILMOR 6.0L
No but my 2012 cockpit heater is not real hot, maybe we should switch where the pick-ups are on the engine???
Sent from my iPhone 4S using Tapatalk
Old 09-30-2012, 09:12 PM
bcd bcd is offline
Boat: 93 Larson 200 SEI, 2002 X Star, 2012 X-2
My heater was always cold. I complained and the installed a 190 thermostat and moved the supply and return ports on the engine to improve performance. As I understand it, they've changed production to the 190 tstat. If you have the kit installed, just make sure that they don't cap the old supply port with a rubber cap (it splits and causes a lot of bad things to happen). The kit is supposed to come with a metal cap now, but they missed mine. Also, make sure they update software to raise the overheat alarm set point. I have to bring mine back in because it occasionally gives me overheat false overheat alarms now.
I didn't get the shower, so I can't help out your issues there.
Old 09-30-2012, 09:53 PM
MASTIQUE's Avatar
Thanks for the tip, covered under warranty I take it, heater should be hot right?
Old 10-01-2012, 01:16 AM
onewheat's Avatar
onewheat onewheat is offline
Boat: 2007 Mastercraft X-15
Our heater blows some serious hot air - I have personally never had the need, but some of the females on the boat REALLY love that option. It's just the factory hear with the MCX.
onewheat
2007 X-15
Old 10-02-2012, 02:24 PM
bcd bcd is offline
They told me Ilmor wasn't treating it as warranty, but would supply the parts and pay for 1.5 hours of labor. I think it took my dealer 2 hours. They didn't ask me to pay for the extra half hour, and if they had, I would have refused.
shower problems, shower temp, x25
