It wouldn't take a lot of exposure to saltwater to make the engine look like this. I suspect you will have to go the full engine rebuild route, but sounds like you need to pull that engine and let the professionals do their thing. Saltwater exposure to the electrical components may be your largest hurdle. Good luck.
CUSTOM WHEEL & TIRE PACKAGES $125 LED TRAILER LIGHT PACKAGE - FREE SHIPPING REBUILDING HOLLEY MARINE CARBS - $289 DELIVERED REBUILT COMPLETE MARINE HOLLEY 4160 CARBS FOR 302, 351 & 454 STARTING AT $450 DELIVERED Email - [email protected] |
#12
thanks for workin' on bringing her back to life...
I'll do my best!
'92 190 Prostar 260hp Indmar. |
#14
Where is the boat located? The heads can be brought back pretty easy with a valve job and some oversized valves and reamed guides. As long as they are not cracked the heads can really take some abuse and still clean up because they don't have any internal oil passages the oil is fed through the push rods. The block could be a whole different story if it went under while running the rods may be bent and if the block won't clean up with less than a .030 over bore you need to pitch it. The cam is toast if the lobes have any corrosion on them at all, the crank is pretty stout and can be ground on both ends if the corrosion is just light surface rust. Also if the crank front and rear seal areas are badly pitted you can have the ends sleeved but at that point you should just look for a rebuildable core. Pull it apart and see what you got. maybe you'll get lucky but things don't look too good at first glance.
#15
Dang...what the heck happened to that thing.....it's only an '05.
#16
I think the previous owner had the back end submerged at some point. We're getting a new long block, cleaning her up and hopefully bringing her back to life.
#17
Any updates?
#18
yeah... updates!
#19
I started a new thread some weeks ago on the updates, have a read through here: http://www.mastercraft.com/teamtalk/...ad.php?t=52162
Tags |
350 mcx seized |
Thread Tools | |
Display Modes | |
