Old 09-03-2012, 12:06 PM
MC209's Avatar
MC209 MC209 is offline
Boat: 2004 Mastercraft 209 Sammy Duvall
Heater
My heater does not kick out warm air in my boat. I got a buddy with a x-25 and he said his only kicks out warm air when he is moving along and not toodling around. So last night I went around our local lake a couple times at 35 with the heater on, and still no heat. any ideas?
Old 09-03-2012, 12:34 PM
jgraham37128 jgraham37128 is offline
Boat: 2010 Mastercraft X2
Is it blowing cold air? I can only assume you do have the fan switch on to make it blow warm air?
Old 09-03-2012, 12:36 PM
MC209's Avatar
the air is just barley warm. not cold but should be way more warm.
Old 09-03-2012, 12:37 PM
MC209's Avatar
I just have a switch to have heat on low or high
Old 09-03-2012, 12:39 PM
Not sure then. I was thinking, maybe you wasn't aware of the switch to turn it on?
I have a 2010 X2 and it blows very warm air when on.
Old 09-03-2012, 12:40 PM
Yes, that's the one I'm referring to that kicks the fan on.
Old 09-03-2012, 12:41 PM
MC209's Avatar
is your air "more" warm when going faster?
jakethebt's Avatar
jakethebt jakethebt is offline
Boat: '96 Prostar 205 LT-1
I assume that you have the hot water tap open or you dont have one otherwise you would never get hot water to the heater core. Do a search on here for this one. It all has to do with where on your engine are you getting the water from. Some on here have moved the factory location for better hot water at idle. I think most of the discussion was around the LT1, but ICBW.
1996 Prostar 205 LT-1
Old 09-03-2012, 12:50 PM
MC209's Avatar
would their just be a switch in the line before the heater core?
Old 09-03-2012, 01:27 PM
501s's Avatar
501s 501s is offline
Boat: 2013 X-30, 6.0L, 2500lbs of Ballast, 500lbs of Lead.
I have a 2012 X-30 with the MV8 and my friend has a 2012 Moomba and the heater is much warmer on his boat then mine. He also has 2 pull out hoses while I only have 1.
If anyone has tips for improving the heat i'd also like to hear them.
2013 X-30, 6.0L with 2500lbs of ballast and 500 lbs of lead.
209, heater
