Old 08-27-2012, 08:29 PM
mca1710 mca1710 is offline
Boat: Chaparral 220
x45 question
I am on a quest to find a nice used x45. I found one the other day with a MCX350 engine in it. What do you all think about this size engine in this boat? Its a 2010 x45 with only 65 hours on it. It comes with a transferable warranty so I am not worried about the engine. I want to make sure I would be happy with the size of the engine.
Thanks for your advice. I hope to be a part of the Mastercraft team soon.
Mark
Old 08-27-2012, 08:34 PM
TheWoons TheWoons is online now
Boat: 2012 X-25
If you don't load it with a lot of ballast it will be ok. If you add a few thousand pounds you'll want a bigger motor
2012 X-25
Old 08-27-2012, 08:44 PM
Boat: Chaparral 220
For that size boat do you have to use all of the ballast? They are advertising it has 1500 lbs of ballast available. For the X45 owners out there do you use your ballast every time you go out?
Old 08-27-2012, 08:46 PM
Boat: 2012 X-25
If you want to surf you will put 2500lbs+ in it. You can wake board with stock ballast
2012 X-25
Old 08-27-2012, 08:54 PM
Cobra Rob Cobra Rob is offline
Boat: Mastercraft X-45
I have an 07 with the 400HP LY6 and my buddy had an 06 with the 350 in it.
I use less gas and have noticeably more power. If you drive to the party spot and tie up should be no problem. If you are going to use it to ride, I personally would not look less than the 400hp. I could tell enough of a difference driving his I would never want it.
Old 08-27-2012, 09:47 PM
Boat: Chaparral 220
Thanks Cobra Rob. I was thinking the boat was underpowered. The seller is upgrading from a 2010 to a 2011 and I bet he is going to order a bigger engine this time. I will keep looking.
Old 08-27-2012, 11:27 PM
scott023's Avatar
scott023 scott023 is online now
Boat: 2008 X45 Switch L18
I absolutely do. I have the L18 in mine, and I can tell you I wouldn't touch a 45 with the MCX in it. Would have to run he LY6, at least.
The surf wake without factory and added ballast isn't where it needs to be, even for a boat of this size. Good luck with your search.
Old 08-27-2012, 11:29 PM
scott023's Avatar
Lol. Beat me to it. The fuel consumption between the LY6 and the L18 is pretty considerable as well. My buddy and I have done the comparisons too.
x45
