Old 08-18-2012, 11:35 AM
surfacetension surfacetension is offline
Boat: 2007 mastercraft X 2 350 mxc
X2 just shut down
My X2 with a mcx just shut down while surfing yeaterday , turned the key off and it started right up , Just wierd ran fine for the rest of the day. If I take it to my dealer does it have a memory? and will he be able to go back and find a code or something?
2007 X2 Slider MCX It's Orange and white
Old 08-18-2012, 11:57 AM
snork snork is offline
Boat: 07 xstar
Roh-oh
might want a fuel pump handy if you hadn't replaced it yet
Old 08-18-2012, 12:32 PM
I have one in the glove box, never let it go below half , I only have about 140 hours on the boat hope I Don't have to change it out already
Old 08-18-2012, 12:38 PM
kskonn kskonn is offline
Boat: 2003 X-30
If you never let it run below 1/2 you probably don't have a fuel pump issue. I have 270 hours on my 11 and no problem with fuel pun. I had a 03 X30 with 750 hours and I never changed the fuel pump. Just never ran the tank below 1/4.
Old 08-18-2012, 12:53 PM
Is it possible that the fuel tank vent was below the water? That would not only cause negative pressure in the tank, but it would also put water in the gas.
Old 08-18-2012, 01:01 PM
We were surfing at the time , I never had it happen before , boat had 3/4 of a tank . Maybe it was just a blip . ran fine the rest of the day
Old 08-31-2012, 08:27 AM
Boat: 2003 X-30
I think Him had an interesting theory. How much weight and how low in the water was the boat?
Old 08-31-2012, 12:45 PM
bjames's Avatar
bjames bjames is offline
Boat: 2009 X-Star LY6
I had that happen a few times, but then I found out that the due to the way I was sitting and turning my body when pulling surfers, my knee would hit the lanyard connection enough to shut down the boat.
Owned:
2012 X25
2011 X25
2009 Moomba LSV
2009 Moomba Outback V
2008 Monterey FS180
Pelican 4 set paddle boat
plastic tug boat when I was 4
Old 08-31-2012, 02:57 PM
kevkan kevkan is offline
Boat: Mastercraft 1985 PowerSlot 351 Ford
I've had stalling trouble with my MCX running at slow speed. I run the blower now, almost all the time, and haven't had any more trouble.
Old 08-31-2012, 03:32 PM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
No fuel tank vent to flood or get underwater.
If it started right up, no hesitation and continued to run fine I would suspect that you bumped the tether kill switch.
It's in a bad spot right above the cupholder. I got tired of killing the boat by accidentally bumping the tether and disconnected it.
'06 X2 MCX
