Old 06-09-2012, 01:52 PM
Streak's Avatar
Streak Streak is offline
Boat: 2006 Mastercraft 197
mcx exhaust manifold leaking
I have a 2006 MCX (197 prostar) in which the (black) exhaust manifolds have developed leaks in the centre of the (frost) plug/covers located at different positions on the manifold itself. It seems others have had the same problem. Not sure if they are frost plugs or covers for the initial manufacturing, but the seem to be a welded portion 1" in diameter that have developed a hole in the middle and now spurt water when engine is running (pictures of others :
http://www.mastercraft.com/teamtalk/...haust+manifold
can you give any advice to repair (I've heard of JB weld), or replacement parts if available (indmar seemed to think that I could purchase replacement "caps" from inboardonline.com and "press" them into place.
If the manifolds are corroding in these places, does it mean they are corroded inside and will that affect engine operation - can this put water into the block??!
Thanks
Craig Brown
craigbrown8@hotmail.com
Old 06-09-2012, 01:58 PM
Boat: Boat
I'm not sure how you linked the photos but its going to a 404 error.
Gone, surfing.
Old 06-09-2012, 01:59 PM
Boat: Boat
They are casting plugs. I know some people have pulled the manifolds off and had new plugs TIG welded in.
Gone, surfing.
Old 06-09-2012, 02:17 PM
snork snork is online now
Boat: 07 xstar
Had the same thing happen to my 04 mcx
had Indmar replace under warranty
Old 06-09-2012, 02:36 PM
Jim@BAWS's Avatar
Jim@BAWS Jim@BAWS is offline
Boat: 1996 PS 190 LT-1/Powerslot
Casting plugs are your first choice. JB Weld marine is your second. Clean the area real good then
apply the JB Weld...Clean and paint gloss black. Casting plugs are avail from any INDMAR and or MC Dealer
Jim@BAWS
Tampa Bay's Exclusive MasterCraft Dealer
www.BAYAREAWATERSPORTS.com
(813) 996-BAWS (2297)
Old 06-09-2012, 03:17 PM
Streak's Avatar
After some in-depth research on this site (thanks to macattack for his input), I found that the exhaust manifolds have casting manufacturing holes that are covered by aluminum caps (welded). These actually act as anodes to the exhaust manifold and corrode over time - even in fresh water.
Tempo fix seems to be JD weld, proper fix: aluminum casting caps from Indmar TIG welded to the manifold after proper removal of the corroded parts.
Once again, I'm impressed with the quality of info and people on this site and will keep using it to help others if I can.
Thanks all
Streak
Old 08-15-2012, 03:27 PM
hurricunning hurricunning is offline
Boat: PS209
Have the very same problem on 04 MCX in a prostar 209 I am negotiating the purchase of right now! New manifolds look to be $727 each on mymastercraft.com. Anybody have an idea of the cost of a full set of plugs and rewelding ballpark?
Cheers, Chris
Old 05-18-2013, 02:10 PM
sp00ky's Avatar
sp00ky sp00ky is offline
Boat: 1994 prostar 205
Ok my 94 205 is leaking from a similar place except there are on the sides. The jb water weld route is what Im about to do.
But replacing these caps requires removal of exhaust manifold/risers? Being that is a 94 and I'm not sure when these have been inspected.
Do I run the risk of damaging anything by removing? Has anyone had this done.
This forum is amazing with quality people.: I did not think i'd ever own an Inboard. Now I finally have a gorgeous 94 205 I am glad I have ya'll backing me up.
Old 05-18-2013, 02:35 PM
Boat: 07 xstar
get yourself some gaskets when re-installing the headers or risers
Old 05-18-2013, 03:25 PM
Engine Nut's Avatar
Engine Nut Engine Nut is offline
You can prevent electrolysis from attacking the plugs in the manifolds by separating the quick drain hose that runs between the manifolds and draining them any time the boat is going to sit unused for more than a couple of days. No electrolyte ... no electrolysis.
Engine Nut
Indmar Marine Engines
Power to the Sport
exhaust, manifold, mcx
