Engine / transmission flange alignment
Just had a discussion with a buddy and his boat (not a MasterCraft) manual says the transmission/crankshaft output flange gap has to be measured with the boat in the water.
Is this true for MC boats as well? I really wonder if my dealer goes to all the trouble of putting the boat in the water just to check the mentioned gap.
2006 X2 |
Maybe the prop adds flotation?
just kidding no idea why unless they think the adjustment will change the packing box leak rate and the want you to be aware ?
Keep a tight line, and a smile on your face. Peace out. 2008 Prostar 214 MCX Previous 93 Prostar 190 1.5:1 GT40 "Left Foot Forward and preferring girls." |
Ha!
![]() Back to topic: In detail, his manual says: boat in water, fully fueled, with a normal load of people. [Edit: Not a joke, he just sent me a picture proving the statement. Boat is a CC Super Air Nautique 210, so more or less similar to my X2] The only reason for the "average load" I can see is that the hull bends when it is in the water. But that's just me. Is there a similar statement in the MC manual?
2006 X2 Last edited by LiquidForce; 08-08-2012 at 09:06 AM. |
One more reason to have an MC inboard.
I cannot imagine that the flange adjustment would have to be done in the water on CCs and it would not matter for a Mastercraft.
2006 X2 Last edited by LiquidForce; 08-08-2012 at 10:56 AM. Reason: Typo, again |
Yes, alignment should be checked on the water, in order to account for the flex in the hull. It is less important on inboard ski boats, which tend to have relatively small and stiff hulls... but it is still the proper way to do it. MC is not immune.
PCM 351w, 350hp |
Always did mine out of water on the trailer. Can you imagine what that would be like with the boat loaded with people and you all bent over trying to do that with your little gauge checking gaps???? Bad enough by yourself trying to get it right.
In the water. If you want perfection with your precision. I found it made more difference when I was using a 3 bladed prop.
