Old 08-01-2012, 03:40 PM
SkiDog's Avatar
SkiDog SkiDog is offline
Boat: 92 Prostar
replace the damn fuel line from the tank! Ethanol gas is the problem! Its eaten up the interior of the fuel line. Happened to my 190. Replaced the line and that remedied the problem!
Old 08-01-2012, 05:15 PM
nrojay nrojay is offline
Boat: 1995 ProStar 190 LT1
the temp never got above 120 even when pulling tubes hard and such, I just read stx221 whole thread wow you may be my "brother from another mother"
so yours ended up being the oil presure sending unit ?
Old 08-01-2012, 05:21 PM
one thing i did notice when test driving the boat was the fuel gguage would go from 3/4 full to zero then back to 3/4 like it was loosing connection but i checked the connections and all was good
Old 08-01-2012, 05:25 PM
LYNRDSKYNRD's Avatar
LYNRDSKYNRD LYNRDSKYNRD is online now
Boat: 1987 PROSTAR 190
Ground may be bad even if the connection is tight.
Old 08-01-2012, 08:29 PM
Todd X14 Todd X14 is offline
Boat: MasterCraft X-14 350 mcx
95% of all problems today in automobiles are fuel related.....Ethanol is the root cause. It eats things and what it cant eat... it coats.
Old 08-01-2012, 08:41 PM
Stx221's Avatar
Stx221 Stx221 is offline
Boat: 1995 Prostar 190, LT1 w/ Powerslot
I think we need to see a picture of that Prostar of yours!
Yes, my issue ended up being the Oil Pressure Sending Unit. Once I swapped that out, all has been good. (Knock on wood!)
Old 08-01-2012, 09:33 PM
Brian B's Avatar
Brian B Brian B is offline
Boat: Brand new 01 X10
Northstar ignition?
My LTR did this. Bilge water would splash the coils. Pulled coils off, cleaned all connections, smothered connections in dielectric grease, problem solved.
Old 08-01-2012, 11:09 PM
Originally Posted by Brian B View Post
Northstar ignition?
Nice fix. Gotta love dielectric grease.
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
SPECIAL PRICING CONTINUES
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
Old 08-02-2012, 12:08 AM
wow!
Guess what I found, while doing some thurough cleaning, (Stx221 we may be kinned) , I pulled the rear seat out and there laid a silver steel box the length and height of the whole rear seat I opened the top and in it was 10 steel plates. I took one out after prying and several choice words was able to get one of them out, I took and weighed one of the plates 100lbs according to the bathroom scale, so I pulled all ten out, then I crawled into the front of the bow and yes there was a bag full of lead bb's I strugled to get it out and weighed it in at 150lbs.
A total of 1,150lbs of added weight, DO YOU THINK THIS MAY BE WHY IT WOULD NOT RUN OUT???? It sure should be alot easier pulling it to and from. I cannot wait to hit the lake Friday, I will report back..
Old 08-03-2012, 04:09 PM
what do you think would this much weight have any bearing on top speed?
engine problems, top speed
