Old 07-25-2012, 12:55 PM
Jaakko K Jaakko K is offline
Boat: Mastercraft x-30 2007
Need Help! Problems with Engine
Hi
I have x30 2007 with 350 engine. When I try to start my boat it only runs 30 or something seconds proberly and then dies. It doesnt matter if the rpm are high or not. And if I try to start it straight a way it wount start or it is realy hard but if I try after 5 min it runs smoothly 30 and then dies.
I just changed our alternator and after that it run smoothly. We ha less than half tank fuel.
I was thinking that maybe the problem is in the fuel pump but I can hear some noise and shacking when I put the power on.
Any ideas guys any help would be much appreciated.
Jaakko
Old 07-25-2012, 01:23 PM
MASTIQUE's Avatar
MASTIQUE MASTIQUE is offline
Boat: Past: 1986 MC 19 Skier; Nautique, 230, 2009, PCM 343; 2012 X-45 ZFT4, ILMOR 6.0L. CURRENT 2010 X14V, ZFT3, RTP-1
Another fuel pump!
Sent from my iPhone 4S using Tapatalk 2
Old 07-25-2012, 02:34 PM
willyt's Avatar
willyt willyt is offline
Boat: ER xstar
any check engine alarms?
1. check fuel pressure. 2. check voltage
Old 07-25-2012, 02:47 PM
ntidsl's Avatar
ntidsl ntidsl is offline
Boat: 2005 197 TT
use search feature on top of page and you'll come up with the solutions...too many variables to answer...but Willy T is correct...you must check things out...check the furl pressure...search and you'll find out how to do that. good luck!
2 at 32' off 34 mph PB July 2006
Old 07-25-2012, 02:59 PM
How can I check the fuel pressure
Old 07-26-2012, 09:01 AM
Where is fuel pump relay and fuse located?
Our local dealer thinks it might be fuel pump relay or fuse can someone tell me where can I find it?
Thanks
Jaakko
Old 07-26-2012, 01:07 PM
willyt's Avatar
Boat: ER xstar
check out threads by HOT-4-TEACHER or 93prostar190
Old 07-26-2012, 01:36 PM
JimN JimN is online now
Thanks
Jaakko
The relays and fuses should be at the rear of the engine, fairly close to the ECM (brain). Do you know what a Bosch relay looks like? That's what you need to look for.
engine
