Isn't the blue on them power coat??
Tim Gone, surfing. |
#12
Voodoo |
#13
VHT wrinkle finish paint. Available at O'reilly's auto on the west coast. I'm sure it's readily available across the country. |
#14
I think it's paint. Whatever it is, was fairly easily removed with Jasco Epoxy and Paint remover.
#15
That's fantastic! I've seen a few valve covers redone on this forum over the years, but that wrinkly finish helps the uncovered fins really pop.
Choose The Right 5mph>Wakeless Speed>32mph |
#16
Peter, This is what worked for me: Apply a good coat of paint to everything (not too thin) and use a hairdryer to evenly heat the paint to it's wrinkled finish. If the paint is too thin, it stays fairly glossy and doesn't wrinkle very well. I hope it goes well for you. Please post some pics. |
#17
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com WHEEL SPECIAL Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. Spare tires too. |
#18
Did you sand after they were completely dry, or was the paint slightly pliable?
#19
Probably want to add some clear coat to the bare aluminum fins to keep it from oxidizing.
#20
Good question. I actually scraped the fins and logo with a flat utility blade about 18 hours after painting. The paint was dry but not completely cured at that point. Then, a short time later I started with the Sandpaper on a block.
