For those of you that have done rebuilds on this carb where did you set the float levels? Level seems way too high but I may have had some needle and seat issues too. I did find a generic guide in the link below but I would think the marine application would be a little different given the angle the engine sits at in the boat? http://www.holley.com/data/TechServi...Carburetor.pdf |
#12
There is a spec in the rebuild kit for measuring the distance between the float and the surface of the fuel bowl while inverted. Generically this laves the float surface level with the top of the fuel bowl while inverted, but there is a range of measurements (15/64"-1/2") by carb number. There is also a measurement for the secondary float that isn't always the same as the primary setting.
Holley 4160 carbs are a breeze to rebuild as long as you follow the instructions completely.
#13
http://www.holley.com/data/Products/...l/199R8339.pdf |
#14
Here are the specs:
#15
Thanks Mr. MC, that's exactly what I was looking for! But unfortunately the settings for the 80319 carb are blank.
My box is still up at the cabin, I can get the PN from it this weekend if your curious. It looked like an MC part though, plain white box. It wasn't a Holley 703-47. I have an email in to Holley tech support, hopefully that solves the riddle. |
#16
#17
Holley got back to me and said they should just be set level. Maybe that's what all the blanks mean in the spec sheet. But I'm pretty sure when I opened up my carb for the first time they were definitely lower than that and the carb was brand new last year.
#18
I have seen them come from the factory with incorrect settings once or twice.
