Clarion remote work with kenwood head unit
When I bought the. Ot it had a newer kenwood head unit, but by the dash at the captains chair there is a clarion wired remote, it is not hooked up and I don't know where the wire is but if it will work I will try to track it down. Anyone know?
Sorry, the Clarion remote will not work with a Kenwood. The radio end of the clarion cable is a 6-pin DIN circular plug about .5" diameter.
The pulse codes are entirely different. Older Clarions were not compatible with typical IR codes so even a learning adapter wouldn't help. Other than Clarion, most hardwired remotes tap into the same infrared board. No hope.
David Earmark Marine
www.earmarkmarine.com |
Def will not work. Depending on the kenwood unit, Kenwood makes wired remotes that you can use if you head unit is compatible.
2000 X-Star, 3000lbs ballast, LTR 330, Acme 1235 14.5X14.25prop. |
Thanks guys just thought I'd ask y'all saved me the time from chasing down the wire and finding out he hard way that it wouldn't work
When I was searching for a head unit I had the remote in mind. I could not find one to fit in the same size hole except a clarion. I went back to a clarion because of that issue. Gotta have a remote.
If you are interested in replacing a single DIN size Kenwood, you could install a Clarion M475 which is the same size and would be compatible with the older clarion remote.
I think Alpine has remotes for there units. $175 for the first and $150 for additional ones. Alpine head unit around $159 with Bluetooth
I don't know! I don't know why I did it, I don't know why I enjoyed it, and I don't know why I'll do it again!
I just installed a Clarion M502 with bluetooth in my 2001. I had to get a special adapter that goes from my old remote to the new stereo. Clarion does'nt make the adapter cable anymore but I did find them on E-Bay. Everything seems to be working just fine and I only spent $59 on the adapter cable and did not have to rewire my boat.
Almost forgot. Here is the part number--ccumra1
