Old 07-15-2012, 08:44 AM
MCVOLS's Avatar
MCVOLS MCVOLS is offline
Boat: '08 X14 MCX Slot
bent strut (?) Do these pics confirm?
'08 x-14, hit a submerged log, immediate BAD vibration. No visible damage from a quick inspection on the lake, but once back to the house, pulled prop, hoping it was just the prop. It did seem to be off a bit on one blade, and I have pm'd Eric at OJ. I snapped these pics, and I don't like what I see. Based on reading and re-reading Krkdrivr's thread, I think my strut is bent. Doesn't appear to be an offset of the shaft to the rudder anymore. Also, shaft is pretty close to one side of the log, although not touching.
Do you guys agree the strut is bent to the left? Could the shaft still be ok or is it likely bent too? Is the shaft too close to the side of the log also?
Thanks in advance for your help.
2008 X-14 MCX
1993 Prostar 205
1982 S&S
Old 07-15-2012, 10:25 AM
93Prostar190's Avatar
Dude something in the water/ air ... I hit something on Friday with my 2008 214.
I think your strut needs to be really checked or repaired. You should also pull the shaft and see if it has any wobble ..... I would guess the shaft maybe ok .... You will at minimum need to re align engine shaft to center every thing up once you have the new strut.
It may be possible that it shifted only because your engine and tranny mount are not tight. So check that just in case.
Also heck your tracking find, my front one took most of my hit. I am replacing my fun on Tuesday and already replaced my prop. I am "hoping" the rest of my hardware is still ok.
2008 Prostar 214 MCX
Old 07-15-2012, 11:50 AM
gts-20's Avatar
gts-20 gts-20 is offline
Boat: 2008 Prostar 214 w/ mini tower mcx
93Prostar190, I need to replace the prop from our '08 214 also. What prop did you go with?
Old 07-15-2012, 11:57 AM
My spare is the same as my stock 13x11 vc by OJ
Here is the repairable one ....Name:  ImageUploadedByTapatalk1342367757.245773.jpg
Old 07-15-2012, 12:19 PM
looks bent to me - to left/port side.... sorry for the hassle... mid summer and damage...
Old 07-15-2012, 10:00 PM
psychobilly's Avatar
You didn't hit anything leave'n out of that spot I showed you, did you?
Old 07-15-2012, 10:12 PM
Tom190driver Tom190driver is offline
Boat: Mastercraft prostar 190 1990 351w
Sorry to hear that. I had the same thing happen, new prop, strut, ( bent the old one back in shape for a spare) an shaft. Now runs smooth. Good Luck
Old 07-16-2012, 08:23 AM
It is most likely bent. Several years ago I hit a manatee while running at a good speed and heading back to the ramp. From the sound of, I thought the whole rear end of the boat was going to missing. After yanking the throttle back and trying to figure out what happened, the boat did not seem to vibrating or anything, so I limped it back to the ramp which was in sight. Turned around and saw several manatees crossing river, one with bad headache.
After getting it back on the trailer, checked everything out, prop not bent and shaft did not appear bent either. Thought myself lucky.
Fast forward about a year, into the next summer. While out, after some pulling, started motor and noticed weird sound, and then silence, other than the engine running smoothly. Put it gear and nothing happened. Shut it down, dove over the side and check to see if prop was there. It was, but shaft was cleanly broken in half. The break was so clean, like glass, you could cut your hand on the edge.
Obviously, it was bent enough to put pressure on the shaft and break it over time.
My advice, get it checked out, by some other method than just visual.
Old 07-16-2012, 04:56 PM
MCVOLS's Avatar
Strut and Prop confirmed. Shaft removal next to know for sure, but not looking good
2008 X-14 MCX
1993 Prostar 205
1982 S&S
Old 07-16-2012, 09:47 PM
MASTIQUE's Avatar
MASTIQUE MASTIQUE is offline
Boat: Past: 1986 MC 19 Skier; Nautique, 230, 2009, PCM 343; 2012 X-45 ZFT4, ILMOR 6.0L. CURRENT 2010 X14V, ZFT3, RTP-1
Not cool!!!!! Hate to hear that!!
Sent from my iPhone 4S using Tapatalk 2
