Old 07-09-2012, 02:20 PM
chevy08bud's Avatar
chevy08bud chevy08bud is offline
Boat: MasterCraft, Prostar 205, 1994, LT1
LT-1 Raw Water Pump- New Seal or Replace
I'm looking to see if anyone has had any luck just putting a new seal in a leaky raw water pump, or if it is more trouble than it's worth? I'm also under the impression that there are different raw water pumps for LT-1 and non LT-1 engines if I do decide to replace the whole pump. If you can shead any light on this subject, I'd appreciate it.
Eric
1994 ProStar 205 LT1
Old 07-09-2012, 02:29 PM
NatesGr8's Avatar
NatesGr8 NatesGr8 is offline
Boat: 05 X-45
if you have access to a bearing/shop press just rebuild it. Easy job with a press.
Guns don't kill people, I kill people
Old 07-09-2012, 04:49 PM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
Pretty easy without a press as well.
Remove the rw pump and knock the old seal out, tap a new one in. Just like a mini axle seal.
I did mine on my 190 LT-1 and it lasted a couple years (at least, sold it). Cheaper than a new pump unless you have alot of hrs then maybe change the pump.
RW pumps are the same I believe between LT1 and non LT1 engines, in fact I'm almost positive my MCX has the same pump. Every Indmar I've sen from mid 90's to mid 2000's uses the same impeller.
Circulating pumps are differnt on a LT1 vs other 350's. LT-1s are reverse cooling with water going to the heads first.
'06 X2 MCX
Old 07-09-2012, 08:40 PM
Craig's Avatar
Craig Craig is offline
Boat: 94 Prostar 190, LT1
LT1 has a different mounting holes. The pump housing is the same but if you buy one from skidim the LT1 pump comes with the correct mounting holes on the flange that attaches to the balancer pulley.
94 Prostar 190, LT-1, Powerslot
Old 07-09-2012, 08:42 PM
CruisinGA's Avatar
Boat: '01 X9 330HP
Check your bearings. Good chance they are shot - mine were.
Bailey
'02 X-9
Lake Blue Ridge
Old 07-10-2012, 06:15 AM
blackcreek blackcreek is offline
Boat: 1997 prostar 205 lt1
3 years and still going strong on my seal replacement.
Old 07-10-2012, 07:28 AM
Bouyhead's Avatar
Bouyhead Bouyhead is offline
Boat: 1996 PS 190
New pump assembly about $200, new seal $13 order both and just do the seal and see what happens. Like Thrall said seal replacement is a breeze no special tools needed.
Old 07-10-2012, 09:56 AM
NatesGr8's Avatar
Boat: 05 X-45
Sorry, yes just the seal is quite easy without a press, i was thinking back to when i rebuilt the whole thing, bearings and all.
Old 07-10-2012, 12:32 PM
chevy08bud's Avatar
Thanks for the guidance. So I will have to take the pump off in order to replace the seal? I was thinking that I would be able to remove the impeller and then use a pick to pull the old one out, then put the new one in with a large deep well socket. Or does the seal have to come out the back? I'm sure I'll figure it out when I have it in front of me, but the boat's 225 miles from me at the time.
