Old 06-30-2012, 07:35 PM
Lars's Avatar
Lars Lars is offline
Boat: PS197
Why's my teak look so bad already?
I spent a couple weeks last fall redoing my teak as per the attached guide. I used this oil: http://www.westmarine.com/webapp/wcs...4#.T--Lx5gUH0s
I did about 6 coats and then put a coat of thompson water seal on top, though it pretty much beaded up on the teak since it had 6 coats o oil.
Now, halfway through the season and the teak looks like it did at the end of last year - all gray! What happened? is that not the right kind of teak oil?
Put on 25 hours so far this year and the boat sits on a covered lift, though the platform probably gets some decent sun.
Old 06-30-2012, 07:48 PM
Hammer's Avatar
Hammer Hammer is offline
Boat: '01 Prostar 195, 310hp
This is the stuff to use http://m.westmarine.com/aHR0cDovL3d3...dW09NTAyNjQ%3D
______________________________
You look like I need a beer!
2001 Prostar 195
Old 06-30-2012, 07:50 PM
Hammer's Avatar
The key is to let it dry between coats, several days. Sand and move on to the next coat. Skip the Thompson's.
2001 Prostar 195
Old 06-30-2012, 08:31 PM
supturb89's Avatar
supturb89 supturb89 is offline
Boat: 1996 Prostar 205
I have had excellent results with this. It can be found most anywhere locally Ace, HD, etc.
http://www.amazon.com/Watco-Teak-Oil-Pint/dp/B003DL72KO
-Aaron
1996 RED Prostar 205
Old 07-01-2012, 01:27 AM
Tom190driver Tom190driver is offline
Boat: Mastercraft prostar 190 1990 351w
overtons /cleaners starbrite teak 3 pack this 3 step system works great.
Old 07-01-2012, 08:49 AM
JBrew JBrew is offline
Boat: 2005 MasterCraft X9
Just recently used this stuff... Worker really well. (and did I say affordable)
Old 07-01-2012, 09:23 AM
LYNRDSKYNRD's Avatar
LYNRDSKYNRD LYNRDSKYNRD is online now
Boat: 1987 PROSTAR 190
Direct sunlight is a killer mine did the same thing year before last so when I got a new cover I made sure it would cover the platform.
Sent from my ADR6400L using Tapatalk 2
Old 07-01-2012, 09:33 AM
JohnE's Avatar
JohnE JohnE is offline
Boat: A 2009 X14
Well you used the wrong product to follow #1's process. He uses teak sealer, the one in the white bottle.
See this thread http://www.mastercraft.com/teamtalk/...highlight=teak
for an alternative to #1's method which is way too laborious and results in an extremely slippery platform. Tommy's method is to mix 80% boiled linseed oil with 20% mineral spirits.
I started with TMC1's method and my platform looked great. But it was slippery as hell and would scratch very easily. So I waited for it to wear off a bit then sanded it down to bare teak again. Used the linseed oil mix and it looks great. Did it yesterday in fact.
'97 Prostar 190 - LT-1
Old 07-01-2012, 10:51 AM
First GET THAT THOMPSON OFF! It's a wax base not good for a wood that needs to breath then use a good teak oil . about every 6 weeks or so i do a little touch up.
Old 07-01-2012, 03:16 PM
swatguy's Avatar
swatguy swatguy is offline
Boat: 2000 X-star
Strip it clean and throw some Sikkens on there. I hate redoing my teak. This product lasts me 2 -3 seasons and looks brand new with zero maintainance. Give it a good cleaning, put the Sikkens on there let it dry. Put a second coat with their silica grip they offer and it will give you traction at no cost of scratching anything. Follow it up with 3rd coat. I get 2 solid seasons on the 3rd it starts to wear. No oiling or maintainance except a stripping every 3 seasons for me.
2000 X-Star, 3000lbs ballast, LTR 330, Acme 1235 14.5X14.25prop.
