I will definitely be doing that in the future. I have owned the boat for 2 years and just took a look at the starter for the first time. I took it apart and the insides were just obliterated, honestly surprised it lasted as long as it did.
#12
I get starters and alternators from a local shop that rebuilds them. You should have at least one shop near you that does the same. Look under Auto Electric Rebuilders in the phone book, or online. |
#13
The bendix wasn't the problem it was the motor inside the starter that someone tried to repair before and just did not do a good job. From everything I have looked at the starter brush plate was completely rigged up. Do you recommend me getting the current one rebuilt? or just buying one they have? do they typically have marine starters at these places?
#14
If you can't fond a shop easily, call a boat dealer or used car dealer to see who they go to for these. Neither can afford to have bad ones, so it should be a safe bet. |
#15
Thanks Jim! Will look tomorrow. Really hoping to try and get to use the new tower befor I go out of town for work.
#16
I'm sure that others are around but my dad was a mechanic and used Jacksonville Starter & Generator, (501) 982-8938 304 E Main St, Jacksonville, AR 72076 (Corner of Main & Oak, Jacksonville AR ) this was 20 years ago, so since they are still around you would hope they do decent work. Not sure about rebuilding your starter with he housing being busted etc but Jim is correct they usually have spares. If you take your starter with you they can probably tell you which way it turns.
#17
The 5.7L cast iron engine has been around since 1954, so I think enough have been scrapped/salvaged to leave a huge number of starters for the re-manufacturing industry to be pretty well set for a long time.
