Old 06-24-2012, 03:42 PM
brookview brookview is offline
Boat: 1983 star & stripes MBCDR719M83G-PD
83 S&S No reverse
Steering cable broke which caused the rudder to rotate 180 degrees and strike the prop and now I dont have reverse . When in neutral prop shaft still rotates froward. Put in reverse the motor dies!! any ideas
Old 07-20-2012, 02:34 AM
cptskier15's Avatar
cptskier15 cptskier15 is offline
Boat: Stars and Stripes 1980
Does it also die when you put it into gear forward? How does it die die, sieze stop or hesitate to a stop?
Old 07-20-2012, 10:04 AM
It died instantly. It ended up being the pinion gear set in the trans
Old 07-24-2012, 06:56 PM
cptskier15's Avatar
Was it an expensive fix?
