Old 06-19-2012, 10:30 PM
beach.bum beach.bum is offline
Boat: 1997 MasterCraft Prostar 190 275hp
Question boat lift brackets
Edit: sorry, i have no clue how this post ended up under the tower forum, hopefully a moderator can move it to a appropriate category. i thought i put it under trailers.
i just purchased a used Hewitt 3000# cantilever lift to lift a 97 PS 190. i need to do some modifications to the lift by replacing the bunks to accommodate a inboard. i plan on using 2x6 horizontal boards for supporting the boat but i am unsure what to use for the metal brackets to support the bunks. What have you guys used to create the brackets to get the necessary clearance to clear the tracking fins and prop shaft? I have seen brackets that are designed for trailers that are 11ga galvanized metal and as long as 24 inches but i just wanted to check and see if you guys had any other suggestions or products that i should consider. is there materials available at a hardware store that i should consider?
here is a link to products that i have seen. is this the route i should go?
http://www.easternmarine.com/16-galv...-bracket-44045
thanks for all of your help in advance. I have learned a vast amount of information about mastercrafts in this forum and want to thank everyone for their time and dedication to making this site a valuable resource.
Last edited by beach.bum; 06-19-2012 at 10:40 PM. Reason: posted in wrong category
Old 06-20-2012, 10:22 AM
jamisonsbrodie jamisonsbrodie is offline
Boat: 1990 PS 190
The bracket in the link that you provided will work fine, along with the swivel piece that is below it. Have you tried contacting a Hewitt dealer? Hewitt makes a nice ABS covererd bunk that would be far superior than using a 2x6 with carpet. They probably run $200 or so but will outlast the wood/carpet by a long shot.
Old 06-20-2012, 09:47 PM
thanks for the feedback. i have not contacted a Hewitt dealer about the brackets they make specifically for the lift. I am trying to keep the cost down as much as possible and figured 2x6 pressure treated lumber and the trailer brackets would be my best option. thanks again for your help.
Old 06-21-2012, 08:18 AM
catamount catamount is online now
Boat: 1987 Prosport 190
Hi Beach Bum, I am in the exact same position as you and was doing some research on this yesterday. It seems like this is a good option... $200 + shipping gets you the brackets and carpeting, and all you do is provide the lumber. They have several kits depending on the size of your lift crossmembers.
https://www.boatliftanddock.com/p-52...-bunk-kit.aspx
Unless I (or you) can find a better option, I will probably pull the trigger on this kit. Please let me know if you find anything cheaper/better!
See my on-going 1987 Prostar 190 "project" thread here!
Old 06-21-2012, 11:35 AM
east tx skier's Avatar
MC Hero
Boat: 1998 Ski Nautique
Here's my old and new boats on our lift (to get different angles). I think our brackets are galvanized steel angle iron, but the cross piece is different.
Previous: 1993 Prostar 205
FAQ
Tyler Ski Club
Old 06-23-2012, 09:08 AM
Bump for the OP, any luck?
Old 06-25-2012, 01:40 PM
looks lit i am going to go with my original find for the bunk brackets and use some U bolts i saw at overtons as fasteners. i am also going to double the 2x6 's to give some additional strength. thanks for all the input guys. much appreciated.
Old 06-25-2012, 02:45 PM
Boat: 1990 PS 190
Check out this place, i have bought a bunch of carpet from them and they seem to have the best prices.
http://www.sturdybuiltonline.com/Boa...ets_c_101.html
FWIW,
I just replaced my bunks with treated 2x6 and carpet to keep the cost down. single 2x6's will be fine. I have 2 lifts with this set up (one with a PS 190, one with a 20ft Bu) and it works great.
lift brackets
