Old 06-19-2012, 11:39 PM
onebadrubi onebadrubi is offline
Boat: Mastercraft, 215V, 2006, 5.7ls
cruise control help
I have an 06 maristar. I have the cruise control function, not perfect pass. I have never been able to get it to can work. I can get the speed to come up in the small window next to the mph. Say I set it at 21mph while sitting at idle. I will have the boat running in idle, hold the on indicator down till the speed comes up in the small windown along with the "lock" blinking. So now I will accelerate the boat above 21 mph and my cruise will never take over. I know on malibu's and some others you will get a beep. I get nothing and the cruise does not take over.
Any help?
Thanks.
Old 06-20-2012, 10:53 PM
Sorry, I am new here, but did I put this in the wrong section of the forum by chance?
Old 06-20-2012, 11:03 PM
AZX9's Avatar
AZX9 AZX9 is offline
Boat: 2003 Mastercraft X9, MXC 350
I have perfect pass and it beeps. I would bet yours should beep as well.
Old 06-25-2012, 10:47 PM
Thanks, anyone else?
Old 06-26-2012, 01:22 PM
H20BOY's Avatar
H20BOY H20BOY is offline
Boat: Mastercraft, X15, 2006, 350MCX
On mine, you have to pass the desired speed when accelerating by a few mph before it will engage.
"Leadership is the art of getting someone else to do something you want done because he wants to do it."
Current Boat: 2006 X-15
Previous Boats:
2000 X-Star
1999 Prostar 205
Old 06-26-2012, 01:25 PM
mark g's Avatar
mark g mark g is offline
Boat: 87 prostar 190
I have cruise on my 197, sounds like your doing it the same as me, no sound when cruise takes over like perfect pass but mine certainly takes over, sorry cant help further.
Old 06-26-2012, 01:40 PM
Hrkdrivr's Avatar
Hrkdrivr Hrkdrivr is offline
Boat: MasterCraft X-45, 2006, L18, slate gray/white
This is the key. You need to get a little above the set speed before it will take over. Just how much over is a mystery, but I usually board at 21 mph and my wife will have to get up to about 25 before it takes it. After it does, we push the throttle all the way up so there's no chance that it "thinks" you're trying to pull power back. Pulling power way back always restores you back to full manual control. (No beep on MC Cruise Control that I know of)
2006 X-45, L18, slate gray/white
I am leaving it as I found it. Take over. It's yours. - Ellis Wyatt, Atlas Shrugged
Old 06-26-2012, 01:50 PM
kodiak kodiak is offline
Boat: MasterCraft x-30 2005 5.7 MCX
This is what is in the 2005 Manual...
On boats equipped with a Cruise Control System, it is possible to review various functions by toggling to the cruise control read-outs on the multi-function gauge explained earlier in this section. Note also that the throttle position must always be greater than the speed set on the cruise control. For example, if the cruise was set at 35 mph but thethrottle position is equivalent to 25 mph, the boat will not reach 35. This is also true of the RPMs. Also, the cruise control cannot be engaged with the boat is at idle speed.
System Start-Up: When the ignition is turned on the cruise control system starts in OFF mode. While it is in OFF mode, the LCD display will show the current time.
RPM Set-Point Adjustment: In order to adjust the RPM Set Point in OFF Mode, first move the RPM/SPEED mode selection switch to the RPM position. Using the +/- switch,select the desired Set Point. The RPM icon will illuminate and the LCD will display the current Set Point. Briefly pressing the +/- switch will increase or decrease the Set Point by20 RPM. Holding the switch will increase or decrease by 100 RPM. The RPM Set Point is limited to a minimum of 1200 RPM and a maximum of 5000 RPM.
Speed Set Point Adjustment: In order to adjust the Speed Set Point in OFF Mode, first move the RPM/SPEED Mode selection switch to the SPEED position. Use the +/- switchto select the desired Set Point. The SPEED icon will illuminate and the LCD will display the current Set Point. Brief presses of the +/- switch will increase or decrease the Set Pointby 0.2 MPH. Holding the switch increases or decreases the Set Point by 1.0 MPH. The Speed Set Point is limited to a minimum of 5.0 MPH and a maximum of 50 MPH.
Turning On RPM Cruise Control Mode: To turn on the Cruise Control System in RPM Control mode, make sure that the RPM/SPEED mode selection switch is in the RPM position and that current engine speed is at least 400 RPM less than the Set Point. Press and hold the ON/OFF switch in the ON position for approximately one second. The LCD should now display the current engine speed, the RPM icon should be illuminated and the LOCK icon should be blinking.
Turning On Speed Cruise Control Mode: To turn on the Cruise Control in Speed Control mode, make sure that the RPM/SPEED mode selection is at least 3.0 MPH lessthan the Set Point. Press and hold the ON/OFF switch in the ON position for approximately one second. The LCD should now display the current vessel speed, the SPEED icon should be illuminated and the LOCK icon should be blinking.
Turning On Manual Cruise Control Mode: To turn on the Cruise Control in Manual Control mode, make sure that the RPM/SPEED mode selection switch is in teh MANUAL(center) position and that current engine speed is at least 1200 RPM. Then press and hold the ON/OFF switch in the ON position for approximately one second. The LCD shoulddisplaythe current engine speed and the LOCK icon should be blinking.
Manual Set Point Adjustment: The Manual Set Point can be adjusted using the +/- switch. The LOCK icon will disappear and the LCD will display the current Set Point.Short presses of teh +/- switch will increase or decrease the Set Point by 20 RPM. Holding the switch increases or decreases the Set Point by 100 RPM. The Manual Set Point islimited to a minimum of 1200 RPM and a maximum of 5000 RPM.
Using Speed Control Mode: Manual Control works basically in the same way that RPM Control Mode does. The difference is that when the system is turned ON in manualmode the Set Point is set to the current engine speed. For example, if the Cruise Control is OFF and the engine speed is 2500 RPM, and the system is turned on, the engine willhold the engine speed at 2500 RPM.
Disengaging the Cruise Control System: There are two ways to disengage the system: Pulling back the throttle will disengage the system at any time. The system remains ON and can be engaged by accelerating the boat until the LOCK icon stays illuminated. Or by moving the ON/OFF switch to OFF It is recommended that the throttle be pulled back before turning off the system.
Old 06-29-2012, 12:40 AM
Kodiak, when I try to do it the speed way, the "lock" will go from blinking to staying on "lock" but the boat will still not be holding it's pace.
Old 06-29-2012, 02:24 AM
tr6coug's Avatar
tr6coug tr6coug is online now
Boat: Mastercraft 2007 X2 MCX
Have you tried it in RPM mode?
'07 Navy Blue X2 MCX
http://www.wakeblaster.com/
