2009 XStar Ballast Pump Location?
I just got some green impellers for my XStar. Does anyone have instructions for installing them? and where the heck are the ballast pumps located?
Thanks! |
on my '05 and '08 xstars they were mid-way up the transome just aft of the engine. two pumps have the impellor up and one pump has the impellor facing down. you may have to take one pump off the transome, flip it upside down, change the impellor, then re-attach it to the transome.
"Tropic corridor, tropic treasure. What got us this far to this mild equator? We need someone, something new....something else to get us through" (James Douglas Morrison/The Doors) |
On an '09, the rears should be behind the carpeted kick panel, you have to remove 4 screws to pull out that panel, they will be mounted on the transom. The KGB pump will be on the port side locker closer to the tranny and the rear seat. You will probably need to remove the side kick panel.
Ahhhhh. I knew they were hidden! Thanks! I will check it out.
What is the purpuse of the green impeller on the ballat pumps?
I no need for a reply, found the info I required. Thanks
How many of you have switched them so impeller side is down versus impeller side up. Is there really that big of a chance of water draining down into the pump housing?
Evil Conservative |
